Got to tear off my plug wires and valve covers so i can re torque my heads and other bolts. Intake valve covers. Rocker arm assembly.
Its all heated up and retracted when cooled. So its time.
Should be good to go here soon. Oil change and coolant. New filters. Oil and fuel. Bam.
D
2008 bmw 528i
1967 ford f100
2014 vw tiguan
2016 kawasaki 250f
2015 KTM rc390
2014 audi tt Quatro s
Braaaaap!
1st radiator from autozone was a bust. 2nd one I ran down to the local radiator and muffler shop. They ordered me up the correct part. Got a 3 row aluminum and plastic one. Got to burp it. Get a temp gauge and time this thing. Got a light gun or timing light from my team lead tonight.
Earlier today it was burping bad and sounded like water was boiling inside. Not to mention it was overflowing from the overflow. So Im guessing I didn't purge or burp it enough. I also couldn't start it after running to fill it up with gas. Thinking or hoping it just overheated.
working on it.
-d
2008 bmw 528i
1967 ford f100
2014 vw tiguan
2016 kawasaki 250f
2015 KTM rc390
Braaaaap!
truck still has an overheating problem. It can idel for 20mins at 190deg but when I drive it...it goes up to 260deg.... so im gonna tear it down and make sure my head gaskets are correct. :/ than a full day rebuild and such.
-d
2008 bmw 528i
1967 ford f100
2014 vw tiguan
2016 kawasaki 250f
2015 KTM rc390
Braaaaap!
Trucks running alright. I used it as a truck several times now. Hauling.
I replaced my valve covers as one was leaking. Also replaced my plugs as they were the same ones from my headgasket blow job.
They all had white tips but i dont think i should b or am not that concerned.
I will try and get a pic of my new radiator. Dosent look like ill be getting to the body work this summer as we have rain. Coming. Prob for the next 8 months here in wa state.
I thought about jb welding some aluminum on my floors just to make it through the winter. Gotta get my heater box and heater core back in order so i can get defrost. Also debating on some tires.
Not to bad but still $ i dont wanna spend.
D
2008 bmw 528i
1967 ford f100
2014 vw tiguan
2016 kawasaki 250f
2015 KTM rc390
Braaaaap!
Great idea and dealio. Thanks for the link.
I dont get it. Truck left my mom and i stranded today. Had to get a jump. Put the battery on the charger tonight and it was at 16%. Guess i shoulda listened to ppl and done the 3g swap.
Any info or tips or just tell me whatsup with that is greatly appreciated as well. Gonna do some research.myself as well. Dang headache or a truck.
D
2008 bmw 528i
1967 ford f100
2014 vw tiguan
2016 kawasaki 250f
2015 KTM rc390
Braaaaap!
Don't be too hasty about the charging system. First, take the battery and have it load tested. Or, if you have and know how, hook up a voltmeter and check it yourself. Then jump it off again if you need to and see if your alternator is charging the battery. I've had several old batteries work fine one day and crap out the next. Especially if your truck's been down a few days without running.
battery charger said it was a good battery. I hooked it up and tightened my ground. battery was at 100% yesterday. I think it was just my ground being loose but like u said ill do the load test on it per this site under the load test section.
-d
2008 bmw 528i
1967 ford f100
2014 vw tiguan
2016 kawasaki 250f
2015 KTM rc390
Braaaaap!
drove the truck all week to work. Got a pile of parts starting to accumulate. Ive been busy re modeling my house which is soaking up a majority of my time.
-d
2008 bmw 528i
1967 ford f100
2014 vw tiguan
2016 kawasaki 250f
2015 KTM rc390
Braaaaap!
Man you should be proud of her. I know you fought some issues with tearing it down again and all but still. You are overcoming problems and you are making great progress.The engine looks fantastic!!! Such an improvement. One thing to add. Any new thermostat i always drill a little hole in the tstat and put the hole in up when i install it/ Lets the air bleed out. KEEP IT GOING!!!!
The Junk that hangs around
67' F-250 highboy Camper special cross breed currently under way http://www.fordification.com/forum/view ... 22&t=86706
1974 Bronco 302 3 speed
1984 bronco 302 c6 35's
1994 F350 7.3 5spd dually.
this is the most recent pic ive uploaded to smug mug. My truck with the new flooring in it. Guy said it was 1400#s but we took out 14boxes I think it was cuz they were returned, open, or damaged.
Thanks manny. I am proud of it. Needs a lot more work but its at least drivable and enjoyable right now.
-d
2008 bmw 528i
1967 ford f100
2014 vw tiguan
2016 kawasaki 250f
2015 KTM rc390
Braaaaap!
new parts are
-tires fireston destinations
- stainless steel fuel line
- vaccum and fuel line clamps
- FORD logo for the hood
-hvac heater control valve
- grommet kit for the firewall
- fuel filler hose for inside the cab behind the seat.
Waiting on some of the parts but plan on working some more on this beast here soon. Already got the line for the fuel in.
-d
2008 bmw 528i
1967 ford f100
2014 vw tiguan
2016 kawasaki 250f
2015 KTM rc390
Braaaaap!
