Mine was the newer style that has the printed circuit board (you can find them with the same plug as your stock truck as well) so I had to get the wire plug from the truck to go with the F600 panel then I cut the old plug off the stock 69 cluster and wired them together to plug into my truck. Here are a couple of pics to better show what I did.wobblefoot wrote:Thunderfoot,I have the same gauge panel I want to put in my 69 F100.Did you have to change the plug or was it direct plug in?
Back of Stock 69 panel
Back of newer F600 style panel
69 wires and plug from instrument panel
F600 wires and plug from instrument panel
Both soldered together
Ready to install in the truck
If you have the older style it will just plug right in as long as yours was full instruments, otherwise you will have to move a couple of wires if I remember right.
