My 69 F100 Ranger
- fire truck
Re: My 69 F100 Ranger
Nice truck man! I really like that color combo.
- 67 ford f100s rule
I want a 390 and a 4 speed eventually. My 70 will be the puller for the 67.TX69F100 wrote:Thanks! That's exciting. I look forward to seeing your progress.jnash40 wrote:very nice finally got my welder shipped to me so now i can finish my bump YES
Yes sir! What are you looking for, specifically?67 ford f100s rule wrote:listen to that 390 rumble. You gotta love an fe. I hope to find one for my 70 eventually
Jeff Penland
70 Ford F100 LWB "Nadine" 302/3 speed with overdrive
If you have to ask you wouldn't understand
"I shall hold the line of right as well as that of glory." English translation of the British Penland coat of arms.
- TX69F100
It's still for sale here:jp2005 wrote:Good job on the install! what did you do with your 360?
http://www.fordification.com/forum/view ... 11&t=51720
- HayHauler
So any updates? Have you taken it to the track yet?
No problem can withstand the assault of sustained thinking. -- Voltaire
- TX69F100
Updates? Yes.
Track? No.
I'm actually in the middle of doing a cam swap (current cam wiped a lobe, I believe, but I was planning a swap anyway as I have been underwhelmed by the Mutha Thumpr).
I will upoad some photos of the swap as I get time. Work has been pretty busy lately.
Track? No.
- HayHauler
YIKES!
What cam are you going with
- TX69F100
Finally decided on a cam, this custom grind hydraulic roller from Barry @ Survival (specs are 280/285 230/236 .556/.556 110):HayHauler wrote:YIKES!What cam are you going with
http://store.survivalmotorsports.com/fe ... -110-.html
I'll post up a few pics of the damaged cam/lifter shortly.
- TX69F100
Here are the photos as promised. I apologize for the quality, as I took these using my phone.
Front cover and timing set removed:
One of these is not like the others:
Bad lifter flipped, compared to a good one:
Cam out, screwdriver pointing at flattened lope:
Close-up of damaged lobe:
- sport71
That sucker really wore down. Barry is a good guy. I've done business with him before. He will help you with your needs like he did for me when I put the
4.25 stroker set up. Best of luck brother.
Ruben
Ruben
- TX69F100
Thanks Ruben. How's yours running?
- sport71
sorry about the late reply, ive been so busy lately. my truck is great, i take it out every weekend,burn a little rubber here and there and love the attentionTX69F100 wrote:Thanks Ruben. How's yours running?
- TX69F100
sport71 wrote:sorry about the late reply, ive been so busy lately. my truck is great, i take it out every weekend,burn a little rubber here and there and love the attentionTX69F100 wrote:Thanks Ruben. How's yours running?
Have you put it on the dyno or taken it to the track with your current setup?
- Joshpow
Nice truck. Looking good.
Josh
72 F-100 Ranger XLT SWB
71 F-100 Custom SWB
67 F-350 Dually Dump
02 F-250 Stroke
71 F-100 Custom SWB
02 F-250 Stroke
- sport71
No dyno, the track yes. And I had no traction, spun the tires half the track, so I'm not worried about adding more power because it has plenty.
