- abe
I washed mine last night! It is my work truck so it really needed it. And it needs a paint job....
1970 F-350 flatbed dump, purchased 9/20/12
1954 F-100 bought from Grandpa in 1977 for $200
Purchased new tires for the rear wheels.fat boys!
Charged the batery again then used it to move my smoker around. I need to find the power drain! and fix the speedo and the fuel guage and touch up the paint...
2015 lifted Toyota tundra 4.6 4wd
2002 Toyota Sequoia 2wd 4.7 auto
1989 Ford F150
1979 Chevrolet C10 350/TH400 14 bolt "Big 10" (DD)
1972 F100 parts truck long bed
1971 F100 2WD LWB 302 aod 3.70 9inch PS pb
1966 International Scout 800
1954 GMC rat rod project Scout frame, inline 6, T90 4X4
1953 Chevrolet Tin Woody
1946 Hudson BigBoy Pickup-ratrod project
1989 Ford F150
- Mancar1
Changed the oil and filter
DD-727
DD-806
AE-35
LSD-39
AS-41
AR-8
DD-727
DD-806
AE-35
LSD-39
AS-41
AR-8
- SoCalRefuge
Betsy has a set of Hooker headers. (I got tired of replacing the old cast iron jobs.) 20+ years later I have to replace a header gasket on the right hand side.
Since I was a smart boy and used high temp anti seize, it was a 15 minute job. No more put-put sound.
SoCalRefuge
~67 F250 390~
~67 F250 390~
I got motivated and got some stuff done and in the pasts few weeks. I mounted led tail lights and removable mudflaps, replaced an axle seal in the 14 bolt, finished up most of the wiring, replaced body mount bolt, built a light flatbed around a tool box a friend gave me, removed overload spring, removed fuel tank behind seat and connected the fuel cell I mounted over the rear axle, mounted narrowed grill, installed an led lightbar, relocated air tank for my york compressor, finished installing power steering cooler, and took care of some other miscellaneous small repairs, adjustments. I even drove it down the highway
. She's just about ready for the trails again.
1967 F250 4wd, 41.5" Rockers
- Abrams
Did a burnout down the ally behind my place.. Those poor poor tires.
- duaneo
Strapped the reeks-of-mouse bench seat to the top of my daily driver for a short trip to the upholstery shop tomorrow morning. It's a bummer because the seat and cover are actually serviceable, but I can't make the smell go away!
1971 F100 - Ugly on the outside, but purty under the hood...
1968 Chevrolet Impala - Family car since 1970, My car since I was 16, in need of bodywork/paint, but otherwise straight.
2004 Mini Cooper S - Daily driver and grown up go-kart
nothing today yet, but in the last week i've assembled my new 300 short block, new rings and bearings. last night i borrowed some tools from AutoZone and got the harmonic damper installed, and installed new tie rods and drop links, installed a new castle nut in the front driver's spindle, and packed some grease in there.
hmm, tonight, what... maybe get the water pump on, oil pump and oil pan, start mucking around with the clutch linkage perhaps?
Spent all day trying to pull the front sheet metal and still ain't done.
'02 BMW 325xi
'69 Ford F250 C.S. Ranger 428 PI with gt 500 heads, racing c6, d60 3.73 limited slip, currently rat rod black (flat black) but going back factory Candy Apple Red / Wimbledon White
- SoCalRefuge
Added speakers to the holes in the doors that have been there for years. Replaced the head unit in the console I made a long time ago. Found out the unit was DOA. I should have a replacement Wednesday.
Started tinting the windows.
SoCalRefuge
~67 F250 390~
~67 F250 390~
ha! just drove into work for the first time since i put on all new tie rods... kinda sketchy, i erred on the side of caution with toe-in and the tires were scrubbing really bad.
just did a tapemeasure alignment in the parking lot at work, not too shabby, probably going to get some yardsticks and do a slightly better job at home tonight, but it is much closer than it was.
now i've got to pull the steering wheel and clock it about 120 degrees, not sure how that changed so dramatically from the old tie rods.
edit:
might be a pita having to always be working on the old truck, but it is pretty cool that you can do an alignment on your lunch break with a tape measure and a pair of vice grips.
edit:
- duaneo
Discovered that the mice in my cab, also set up shop on top of the instrument cluster. Pulled the cluster, disassembled it, cleaned it. Discovered that the mouse urine corroded the metal fascia inside the instrument cluster. Stripped and painted THAT too. Ordered a new circuit sheet for the back of the cluster, new bulb sockets, and a set of LED bulbs for the instrument cluster. Installed 2" voltage, oil pressure and water temp gauges under the dash.
Duane
Duane
- ximy
Darn rodents!duaneo wrote:Discovered that the mice in my cab, also set up shop on top of the instrument cluster. Pulled the cluster, disassembled it, cleaned it. Discovered that the mouse urine corroded the metal fascia inside the instrument cluster. Stripped and painted THAT too. Ordered a new circuit sheet for the back of the cluster, new bulb sockets, and a set of LED bulbs for the instrument cluster. Installed 2" voltage, oil pressure and water temp gauges under the dash.
Duane
having new 275/60/16 tires put on my rims
1967 f250 428
put the carb and battery back on it, after that I put some fresh gas, topped off the transmission fluid and brake fluid and drove it to get lunch after it sat since april 2013 without being drove
1971 F-100 swb 401 fe , edelbrock intake, cam, valve covers, longtube headers with twin 2.5 inch exhaust, aluminum wheels.
1965 Mustang 350 glide 7.45 at 90mph
1972 maverick 460 swap in progress
2002 z28 a few bolt ons
