- 68FORDJBM
Painted in a new bed/floor liner before taking it to a car show sponsored at work
- farmallmta
WITH my bump, I mowed vacant lots & scared a Mercedes driver
My town has LOTS of highway and road construction going on so major arteries and side streets are quite congested with traffic. I encountered the classic rude/lawbreaking driver who decided, after seeing me pull up to an intersection, to drive forward and block said intersection so I wouldn't be able to pull out into the lane I needed to be in.
Bumpsie decided she would just ignore Mr. Red Mercedes Prick and just eased herself on out nudging her nose right into the gap, anyway. Mr. Red Mercedes Prick actually attempted to pull sideways and forward as much as he could thinking Bumpsie would let rude pricks driving red Mercedes intimidate her. Bumpsie just kept on easing out, forcing Mr. Red Mercedes Prick farther and farther over until finally he had the decision to stop and let Bumpsie in, or to persist and hit the car beside him or the solid front bumper and grill guard of Bumpsie. Well, she won. She got her place in the lane to the angry honkings of Mr. Red Mercedes Prick. Then she instructed me to stick my arm out the window and flip him off on her behalf, so I did. She doesn't like snotty pricey foreign cars or the snotty pricks who drive them, apparently.
- farmallmta
Odd vacuum leak started, found, and fixed!
Rita started running rough. I traced the problem to a vacuum leak at the carb-to-manifold gasket. Just a slight deformation caused the gasket to develop a leak. Fixed it and she runs great again. She shows me lots of love when I baby her with attention. What a gal!
See , your truck looks too nice.farmallmta wrote: I encountered the classic rude/lawbreaking driver who decided, after seeing me pull up to an intersection, to drive forward and block said intersection so I wouldn't be able to pull out into the lane I needed to be in.
In my old junk I am given the right of way , even if it's not my turn.
- farmallmta
Gosh, 3 problems pretty much all happened at once, and I just got the last of the three addressed. First was rekit of the carb, which is a factory manual choke and factory hand throttle plus foot throttle Autolite, tag # C6PF-A. The second was a vacuum leak under the carb. The last one was a worn distributor shaft, requiring replacement of the distributor. Rita's happy again!
At least you can fix it yourself,
All three would stump most modern mechanics.
- farmallmta
You're right about that. One shop I go to for front end work has 5 mechanics who can fix nearly nothing without the code reader telling them what to do. Carburators? Pffft! Forget it.cep62 wrote:At least you can fix it yourself,
- farmallmta
I used to drive a pretty hideous '84 Dodge D-250. Yes, it always got the right-of-way. A very wide berth. Pretty much granted quarantine. People wouldn't even park next to it in parking lots.cep62 wrote:See , your truck looks too nice.farmallmta wrote: I encountered the classic rude/lawbreaking driver who decided, after seeing me pull up to an intersection, to drive forward and block said intersection so I wouldn't be able to pull out into the lane I needed to be in.
Finally found some like new West Coast Jr mirrors for my 72. Felt like I was searching forever, didn't wanna pay crazy ebay prices. Got them locally for $75. I'm pretty happy! Now my truck fits comfortably in the driveway.
- Speedpin
Productive day yesterday, exhaust, and new Qa1 springs up front. Went from a 600lbs 8 inch spring (as you can see, compressed and coilover adjusted almost to the top) to a 650 lbs 9 inch.
1968 f100 Ranger
Body swap over 02 Lightning, 5.4, Auto
- Speedpin
exhaust
1968 f100 Ranger
Added a steering stabilizer. I helped tighten the steering.
Installed a new solenoid and starter. Then I ordered a Superlift leveling kit at 4wheelonline.
- farmallmta
What my bump did for me today
Below, the technique we're using for the radiused corner of the fence. It's 3 runners designed as bowstring trusses. The sheet metal will wrap around it. Also to be hauled to the site by Rita. She's a working girl!
- hfdco4
Nice fence work! I haven't done anything to my mistress at all. too many home projects and other distractions
. I have a feeling it will be cold weather before I get to spend time with her.
FE390PC
