My "$50 Paintjob" has begun... [LG. PICS]
71 LONG BED
re: My "$50 Paintjob" has begun... [LG. PICS]
Post by 71 LONG BED »
I know it isn't the color you were looking for, but it is nice and shinny! :D
John Member #1549
Image Image Image
spartman
Post by spartman »
It definitely is purple in the vid.
Not a bad color though.
69F110
Post by 69F110 »
Yep...I saw the purple that time...more of a hue or a clooudiness when the light hits it right...but there nonetheless.
Steve Davis
Pastor and U.S. Army Retired
towens
Post by towens »
What do you think about a John Deere green? :P
TRAVIS OWENS
"Never argue with an idiot; they will only drag you down to their level" -Anonymous
1972 F-250 CAMPER SPEC: SPORT CUSTOM 360 2WD; C6
1995 Ford Mustang V6; C4
1981 Honda 70c Passport Cub
1982 Honda Trail 110
green70
Post by green70 »
what if you just used a spray gun?
waynaferd
Re: My "$50 Paintjob" has begun... [LG. PICS]
Post by waynaferd »
FORDification wrote:a very lengthy thread in a Mopar forum where they
That wasn't ramchargercentral, was it?
A 72 F-250 Hi-Boy "project" ( that means sitting untouched for 3 or so years)
And a little 94 F-150 Flareside, 7" higher and 35's...
67F250CS
Post by 67F250CS »
http://board.moparts.org/ubbthreads/sho ... art=1&vc=1
Here's the link. It was on a Mopar board.
1967 F250 Camper Special
10MPG with key off, in neutral and going downhill!
rd100
Post by rd100 »
So whatever happened???
kaptnkaos
Post by kaptnkaos »
I just read the article on Mopar again... somthing I didn't mentioned was to only thin with mineral spirits... I've read a couple of other articles about painting with this process... the other articles really stressed to thin with mineral spirits only. Thining with acetone or other chemical agents will cause the paint to flash (dry to fast) and cause orange peeling.
I have every intention of painting all 3 of my bumps that way... starting with the bump trailer to work on my technique.
KaptnKA 8) S
r3vo_3vom
Post by r3vo_3vom »
i like the idea of a $50 paint job. im looking forward to see the end results yall come up with.
matt
Matt
"I have as much authority as the Pope, I just don't have as many people who believe it." George Carlin
'68 F100 Ranger LWB 2wd 360ci C6
'75 Chevy 3/4 ton Flat Bed 350ci 4x4
'03 Yamaha Road Star Warrior 102ci
killakobra
Post by killakobra »
i've had far better luck spraying than i have with rolling. i've got part of a cab painted and after 3 reduced coats and a sand, it came out fairly shiny.
1967 f100 stepside 300ci I6
1972 longbed trailer
carcrafter22
Post by carcrafter22 »
Serious question not trying to knock this but I am curious.
I can get single stage paint in just about any color from my local auto paint guy for $100 for a gallon, I can get hot rod flatz in pearl, metallic or regular colors for $150 to make 1.5 gallons, with either of these paints I can just do the body work (like I would have to do with the $50 paint job anyway) then just shoot it and basicly be done in a weekend. With the $50 paint job I would probably have a weeks worth of work into it due to having to sand between coats.
Do you guys feel that its worth saving the $50-$100 and do the work or spend the little bit more money and shoot the paint in a weekend? Do you think the single stage automotive paint would look much better than the $50 paint job or about the same?
67 F100 sc/sb 07 Crown Vic IFS, 94 Lincoln Mark 8 IRS, isuzu 3.9L diesel w/ HY35 & HX 52 compound turbos and 370cc custom injection pump,T56 6spd trans, 18" 07 dodge magnumm wheels, old air products A/C (for a 66 mustang LOL). 32 mpg's so far, around town
kaptnkaos
Post by kaptnkaos »
The quality of a paint job is more determined by the prep-work that went in into it, than the quailty of the paint that goes on top... though a better quallity paint might give slightly better results.
When I was in the Air Force, I bought a '65 Mercury Comet Caliente. That was back in '77.
It was painted with Rustolium and a professional quality paint brush for enamels.
I promish you could not tell that it had been painted with a brush. It was as good or better than any Maaco paint job I've seen. Again, the prep work was done right so the quality followed through the end product.
Until the last few years, there was only 2 kinds of auto paint, enamal and laquer, so this painting style has been around for a long time. it just took someone to bring it back for it's popularity to come back.
It was used on farms, homes and has been used on nearly everything metal that can be painted.
When the Mopar thread came out a few years ago, Rustolium was runnin' $25-$30 per gallon, now it's around $35 per gal.. Most vehicles take about a gallon, add in a gallon of mineral spirits and your around $42-$45... everything else will run about the same as it would using any other type of paint.
Besides the higher cost of piant, there are other variables that need to be included when you are using different types of paint.
You have the cost of a compressor, spray guns, moisture traps, not to mention setting up or renting a paint booth... I don't even want to try and guess how much the cost has gone up and not even a drop of paint has touch the vehicle. Try painting it in yer driveway, like you can with Rustolium. I wonder how much over spray you can get on yer neighbors vehicles.. especially when you take into account that 1/3 rd of the paint you sprayed ended up in the air as over spray... the cost of the wasted over spray would fully pay for a gallon of Rustolium...
In the true spirit of a do it yerselfer, I'm gonna paint my bumps with enamal, a roller and a paint brush.
KapntKA 8) S
convincor
Post by convincor »
Keith, don't know if you've done anything as far as paint yet, but...I painted this boat trail with Rustolem. Bought the Royal Blue and Black. Just kept adding a little black to the blue until I got to the color I wanted which just about matched the boat perfect. Dam I wish I kept that boat. :(
"Still Plays With Trucks"
onetuford
Post by onetuford »
how come I cant see any of the pictures? They just show up as white boxes with red x's in them.
"I'm not saying, I'm just saying"
1972 Ford F250 C/S XLT 390 NP435, purchased from the son of the original owner, now named Yoda
1967 Ford f100, currently. (2nd Titled owner) Now named Captian Hook
