Holy crap... that's a lot of info to absorb.
Ok... I understand the part about the dissimilar metals and corrosion. However, it seems to me that you are saying that the headlights, cabin lights, and dash panel lights are fed by the Black/Yellow wire and no fuse, and are protected by a circuit breaker in the switch.
But that doesn't make sense, as tracing the Blue/Red Stripe wire from the panel connector down takes it through the fuse block, and the fuse block is marked "dash panel" or something like that.
I guess what I'm saying is that power to the dash lights HAS to run through that fuse... which is returning no juice. So where does that fuse get IT'S power? It has to come from the switch, right? If not, where does the power to that fuse come from? The Black/Yellow wire directly?
Keep in mind... my headlights work fine, as does my cabin lights. It's ONLY the lights on this blue/red stripe wire....
I swear I'd go insane if I were an electrician.
