, Well I ended up getting the '67 Parts truck I had mentioned before! It is VERY solid compared to my truck, and for the most part is rusted in places where my truck is solid so I shouldn't have any problems making one solid truck out of the two
. I am very pleased with how solid the floors are on this truck however t does need some attention at the kick panels (Solid in my '71) The rear/front parts of the rocker panel (Again solid on my '71 for the most part) And there is one small hole in the cowl that will need new metal (Solid on the '71). The Passenger's side Inner Fender is in way better shape than mine although it isn't perfect, but I will probably be using it since it looks better, the hood is WAY more solid than mine. However the lower doors aren't perfect (Small rust holes that I intend to patch but the biggest hole in the bottom of the door so far is about the size of a dime, much better than my lower doors!) Also the fenders are toast toward the rear of the wheel but mine are good so I will be using them. Then there is one good sized hole rusted out of the outer skin of the tail-gate (Again it will get patched w/ metal from mine but other than that it is pretty straight except for one dent where-as mine has too many dents to count) Also it has rust in the front drivers corner of the bed right at the 90 degree seam where the front panel and quarter panel meet which is pretty rough but again my truck is solid there and the floor is perfect on this bed aside from some rust on the lower part of the fender well. Basically I'm VERY pleased with the parts truck with the exception of the fact that it has a '67 cab but '68-72 doors, and it also has a '68-72 hood but that's not a big deal even though I was hoping for the '67 doors. This truck also has a 4bbl intake I might just use, my guess is it is off of a Mustang or a Fair-lane with a 289 based on the casting number (C5OE-9435-C). I've also been thinking about using the 3-speed in the '67 as I am really fond of the 3-on-the-tree set-ups and the fact that nobody else at my school could drive it is another plus
. Anyone have any comments as to the street-ability of a 3 speed vs. the T-18 I've got in the '71 currently? I've probably gotten more to say but I owe you guys some pictures:
Here's a picture of the truck loaded up on the trailer at about 5AM Sunday. We ended up going up to Winston Salem to get it later on Saturday (3PMish) and by the time we got there and changed the tire, pushed the truck on the trailer, talked w/ the owner for a while and all of that good stuff it was already 9:30, so we decided to stay in a motel rather than drive 4-5 hours back home at night w/ the truck loaded and get some much needed rest.
Here's a picture of all of the junk that was in the cab of the truck AFTER the P.O. cleaned it out a bit
Here's a picture of some of the stuff laying in the bed again AFTER the P.O. cleaned it out
. I ended up with a bunch of trash, a spare tire, a mid '80s GM bench seat, a mid '70s-80sish Chevy van Grille, a '75 SBC Air Filter housing, 2 Oregon 16" Chain-saw chains NIB, Some Chrysler V8 Valve Cover Gaskets NIB, A few inline-fuel filter replacement filter elements, some carburetor cleaner, some sand-paper and a whole lot of other crap
This is what the truck looked like after we pushed it off the trailer.
Then I cleaned out the bed, only thing left is some tar-like gunk on the front driver's side part of the floor.
The cab after I cleaned it out.
The lower part of the passenger's side of the hood, in WAY better shape than mine!
Nearly rust free battery tray compared to mine that is.
4bbl intake I might end up putting on my 302
The absolute worst part of the bed, but the good news is that my '71 is solid there so I can patch it pretty easily.
The rear slider window, it is missing the lock on it and it looks like it was tinted by someone that didn't know what a straight edge was for when cutting film
, so I peeled it off almost immediately after cleaning the cab out.
'67 Heater Controls and Rear-View Mirror, still wish it had '67 doors though
The worst part of rust in the cab floor, after crawling under it I noticed that the P.O. coated the floor in bed-liner and after peeling parts of it back it revealed rust-free metal
. Only other rust in the cab is in the kick-panels and front/back rocker panel as stated above and I can patch those places with metal from the '71.
I probably won't be making much more progress as the parts truck drained my wallet, and school is starting back on Wednesday which is also my 15th birthday
, Yay school
. So I won't be making as much money since I can't put in as many hours that and I'm going to have to find a different job that will allow me to work more flexible hours during the school year. But I will be working on the bump as much as time/money allows and will try and make sure you guys get an update every once in a while. With that said my new game plan is:
-Pull the '67 bed and coat the bottom of it after knocking off all of the rust, and patch anything I need too on it and the tail-gate. Also I get to sand out the bondo the P.O. decided to put in the trim holes
, and weld them shut.
-Then I will patch the tail-gate and then put the '67 bed on the '71 frame.
-Then I will pull the '71 cab and Strip-POR-15 the frame there and finish running brake lines to the M/C and install the '67 cab after patching anything needed.
-Next I will pull the front clip on the '71 again to strip the frame and POR-15 it, then I will patch what is needed on the fenders from the '71 and the hood on the '67 and re-install it also doing the front suspension and brakes as well as brake lines and fuel-lines.
-After the body is back on I will align the body panels and start finishing up the body-work on the truck, and I will probably remove the Ranger drip-rail trim and windshield/rear window trim. Also I will be using my West Coast Jrs. on the '67 passenger's door and the '67 driver's door skin (or should I say '68-72 doors) and my glass and vent windows due to the over-spray on these windows
Stay tuned!
