I think you have my Ph # Chris, I'll sell you the grill and the bed as a package for $450.
let me know if you're interested in the grill.
When you push a lot of power through them the drums explode. I have a friend that was recently injured from an exploding drum and had his leg blown apart. Every automatic I own gets one now.averagef250 wrote:Do Arizona TH400's explode?
No, still has 3" of bump travel.1972hiboy wrote:dang, that ranger has been around the block a time or two......is it resting on bump stops?
6 golf cart batteries at 62 pounds each. 372#elgemcdlf wrote:Might want to run that across the scales. I come up with an average battery weight of 58lbs based on your numbers. Sounds a bit high to me. My large deep cycle doesn't weight 58lbs. Granted I did not give anything to the lawn tractor batteries but then again what do they weigh? Maybe 2lbs each.
I believe it, I sell roofing and building supplies, and the pallets of roofing weigh in at 4800 lbs. We always have guys coming in with their 1/2 ton whatever's wanting to pick up a pallet...That's only 1,639. The scrap ticket was 1,800 plus pounds though. I guess I should have taken a picture of that but I really don't want the amount I sell lead scrap for public.
