67' longbed build
- pedro69ford
Re: 67' longbed build
your welcome,thats what were here for.good luck,,
I got another one to shoot towards you I ain't got no dash lights or low beams could it be a possible bad headlight switch or what.
- pedro69ford
so you have high beams but no low beams,is that right?
- pedro69ford
i would check all the grounds for good connections thats a real problem on our bumps..try to turn the headlight switch left till the dome light comes on and back to the right again a few times could be dirty,you could try another switch if you have one handy,or try cleaning that one up some,
Is the blue light on the dash mean high beam? If so, i have the same problem.
2008 bmw 528i
1967 ford f100
2014 vw tiguan
2016 kawasaki 250f
2015 KTM rc390
2014 audi tt Quatro s
Braaaaap!
1967 ford f100
2014 vw tiguan
2016 kawasaki 250f
2015 KTM rc390
Braaaaap!
- pedro69ford
yes the indicator light on the dash is illuminated when the high beam switch on the floor panel is activated.
I will check that when I get home this afternoon and let you know what I find
Well I ain't got no dome light dash lights or low beams I tried moving the switch back and forth nothing happens I haven't got the dummy lights comming on either when I flip the switch over to on any ideas
Fuses are good they ain't blown
Could it be headlight switch causing the cluster lights and low beams not to work
- pedro69ford
my guess is the headlight switch is shot.
- pedro69ford
let us know what you did and the results,thx
2008 bmw 528i
1967 ford f100
2014 vw tiguan
2016 kawasaki 250f
2015 KTM rc390
Braaaaap!
1967 ford f100
2014 vw tiguan
2016 kawasaki 250f
2015 KTM rc390
Braaaaap!
Well I got my low beams working replaced the dimmer and headlight switch still no gauge or dome lights though what's next dome bulb looks good
One other thing I have no flasher cylinder for the emergency lights but it does have this square looking box with to prongs on it could that be it?
