68 F100 2wd
alvinator
re: 68 F100 2wd
Post by alvinator »
made some good progress this weekend. I was able to do some test fitting on the truck and get the doors aligned. Just have a few small spots to fix, prime the bed and check it for high/low spots, then she will be a go for paint. Hoping that I will be able to paint the truck, the weekend of May 12th.
dablack00
re: 68 F100 2wd
Post by dablack00 »
Looks good so far. Can't wait to see the final product.
thanks
Austin
alvinator
re: 68 F100 2wd
Post by alvinator »
okay, the truck is getting close to time to paint. It has taken a bit longer than expected to get it just right on the body work. My plan, at this time, that since my interior is gonna be Blue/White, i was looking at trying to do a close copy of this paint job for my truck:
alvinator
re: 68 F100 2wd
Post by alvinator »
layedout72
re: 68 F100 2wd
Post by layedout72 »
i dont think that would look good on the bumpsides. the body line is nowhere near the click sides styling. keep it a sinple blue/black two tone with the bump being silver, if your set on those colors. dropping the two tone line down like he has, will just throw things off in my opinion.
mljjones67
re: 68 F100 2wd
Post by mljjones67 »
I like it.!!
69bumptruck
re: 68 F100 2wd
Post by 69bumptruck »
I think it would work if you use the line of the bump rather than the hood. Aside from that, I think it would look pretty sweet. It would be nice to see a custom paint job on one.
David, owner of:
1969 F100 SWB (restoration in progress)
http://www.cardomain.com/ride/2317125
mrsnicks
Post by mrsnicks »
I may have missed it, but do you have a write up for the mustang gas tank install Alvinator? With lots of pictures and measurements and technical stuff in it?
Thanks,
Patrick
Chevrolet
1969 F100 4X4 Highboy 390 3sp
1969 F100 SWB 2wd Auto 351w
1972 F100 Ranger XLT 302 Auto
http://mrsnicks.blogspot.com
layedout72
re: 68 F100 2wd
if you used the bump line instead it may work better, but I would look into getting just a chrome 50's style trim airbrushed on, instead of all those bubbles!
alvinator
re: 68 F100 2wd
Post by alvinator »
i did not do a write up on the gas tank. I just got a 20 gal Mustang tank, made a brace around the tank to attach the tank too, then I made four braket to attach the brace to the frame of the truck.
alvinator
re: 68 F100 2wd
Post by alvinator »
picked up the tires and wheels this weekend for the truck
customcrewcab
re: 68 F100 2wd
Post by customcrewcab »
shinny 8) :D
dablack00
re: 68 F100 2wd
Post by dablack00 »
They look good.
XLT
Re: re: 68 F100 2wd
Post by XLT »
layedout72 wrote:if you used the bump line instead it may work better........... all those bubbles!
I agree. And bubbles.... :hmm:
Anyway, if you are looking at the quality of the example you posted, you will end up with something really nice!
XLTrucks from my town
alvinator
re: 68 F100 2wd
Post by alvinator »
I found a guy that does airbrush for a bodyshop across the street, said that he would do the airbrush on the truck and make it close to what is on there (making a few minor changes) and do it for $300.
