Thanks! I hope I make it.cumminskiller wrote:Nice! You're cruisin'! You can make in 6 months!
68 f100 restoration.
- Fordkid68
Re: 68 f100 restoration.
Adam
My first truck,
^^Build Thread^^
(no other projects, YET!)
My first truck,
^^Build Thread^^
- Fordkid68
I have not been able to get a lot done in the past week, but I did make some progress. I have been working on the heater. I tore it apart and cleaned everything. Now I just have to wait for it to stop snowing again to paint it!
This is before I tore it apart. I even found an original stamping on the fiberglass heater box. Here are parts cleaned and ready for paint!
Adam
My first truck,
^^Build Thread^^
My first truck,
^^Build Thread^^
- Fordkid68
Well, it is still cold outside here, but I still painted the heater parts. I just sprayed them in the garage, and then hung them up in the basement to dry. I used Rust-Oleum Gloss black, and for some reason it was really runny, but hopefully it will be okay.
Adam
My first truck,
^^Build Thread^^
My first truck,
^^Build Thread^^
- jimmy828
Looks good. I think the rust-o-leum paint takes to long to dry/cure. That's what i used until i switched to VHT which i like a lot more.Fordkid68 wrote:Well, it is still cold outside here, but I still painted the heater parts. I just sprayed them in the garage, and then hung them up in the basement to dry. I used Rust-Oleum Gloss black, and for some reason it was really runny, but hopefully it will be okay.
- Fordkid68
Thanks for the tip! I have never heard of VHT, but I will definitely look into it.jimmy828 wrote: Looks good. I think the rust-o-leum paint takes to long to dry/cure. That's what i used until i switched to VHT which i like a lot more.
Adam
My first truck,
^^Build Thread^^
My first truck,
^^Build Thread^^
- Fordkid68
Well, after a few days of working on it, the heater is finally assembled! I wasn't happy with the paint finish on the fiberglass box, so I sanded it down and repainted it. Then I assembled it with a seal kit from LMC, and a core from Rock Auto.
Now on to bigger and better things!You do not have the required permissions to view the files attached to this post.
Adam
My first truck,
^^Build Thread^^
My first truck,
^^Build Thread^^
Thanks for this post and the updates. I'm finally getting back to a 67, my first vehicle, and I'm looking for inspiration. I got it back in 1986 and it has sat and been pretty bad, but its making headway now.
- Fordkid68
Welcome to the forum! Looking at other peoples projects is a great source of inspiration!lontron wrote: I'm finally getting back to a 67, my first vehicle, and I'm looking for inspiration. I got it back in 1986 and it has sat and been pretty bad, but its making headway now.
Adam
My first truck,
^^Build Thread^^
My first truck,
^^Build Thread^^
- jimmy828
heater box looks good. Hard work pays off
- Bullitt74
Well done young lad!!
Tip: use SEM vinyl/plastic dye for plastic stuff (like your fibreglass heater box), and you’ll be surprised how nice that stuff turns out. I like the satin black...
Steve F.
Red Deer, Alberta, Canada
- Fordkid68
Thanks for the tip! I will definitely try that!Bullitt74 wrote:Well done young lad!!
Adam
My first truck,
^^Build Thread^^
My first truck,
^^Build Thread^^
- Fordkid68
I have been stripping more paint off the firewall, and found more rust.
Got it cut out. Patch lined up.
Adam
My first truck,
^^Build Thread^^
My first truck,
^^Build Thread^^
- Fordkid68
Here it is all welded in.
Almost ready for paint.You do not have the required permissions to view the files attached to this post.
Adam
My first truck,
^^Build Thread^^
My first truck,
^^Build Thread^^
- Bullitt74
Looking good!
For your butt welds, try leaving a gap about the thickness of your metal. You should get a bit cleaner, tighter weld.
Although it looks like you’re doing a fine job as is!
- Fordkid68
Thanks bullit74! I will try that.
Adam
My first truck,
^^Build Thread^^
My first truck,
^^Build Thread^^
