my green 68
- tybob81
Re: my green 68
newly covered 95 f150 seat.
- tybob81
Re: my green 68
Dusty engine compartment. Doing some rerouting of the painless harness.
Re: my green 68
how did you do the wood in the bed?
- tybob81
Re: my green 68
I built new rear and center crossmembers and modified the front crossmember. Made a track on the sides for the wood to slide into also.
Re: my green 68
Wow, that has got to be one of my top 10 favorite bumps. Very, very nice.
1970 F250 Camper Special
Re: my green 68
BiggDogg wrote:Wow, that has got to be one of my top 10 favorite bumps. Very, very nice.
- undertakerman
Re: my green 68
I like your color. Green is one of my Favorites. I'm restoring a 68 Flareside 8' bed and I'm painting it Sassy Grass Green which is a 69-70 Mopar color. I use to have a 69 Roadrunner that was Sassy Grass Green with Black interior. This interior will be Black on Green. Good looking truck. You did a great job.
You know man can live alone, but he cannot live without Peanut Butter and Grape Jelly.
Re: my green 68
Great looking color. And awesome work on your truck. I only hope I can do that well on mine.
Re: my green 68
that is the coolest green i have ever seen.tybob81 wrote:[ Image ]
Re: my green 68
nice color and it looks that u have done a great bodiy work also!!!
- tybob81
Re: my green 68
Thank you.....I have a ton of hours blocking this truck till it was straight as an arrow.
Re: my green 68
Hey tybob81,
I see you have a tilt column in your beautiful truck, what brand and part number did you use?
Any problems with the install ?
TIA,Calvin
TIA,Calvin
1967 Ranger,Short bed,390,C-6,9 inch,4 BBL.,intake,cam,headers,3:55 Posi.,A/C,Power steering,Power Disc Brakes,Automatic trans.DJM dropped I-beams,flipped rear hangers,headlight harness upgrade.ExTang tonneau cover "Old Blue".
http://s508.photobucket.com/albums/s328/BigSxy96/
1967 Base model,352,2bbl.,3 on the tree,short bed,3:25 9 inch "Rusty".
1967 Mustang coupe-show car/garage queen.Small Block,alum. heads,Nitrous,4:11Locker,Areospace brakes "Mystang".
1996 F-250 Powerstroke-Big intake,exhaust,injectors.(Nice Smoke Show) "Big Sexy"
- tybob81
Re: my green 68
It is an early IDIDIT column for a 67-72 truck. It is the metal housing one. I think they have a ford plug now, nut this one had a gm plug and o made an adapter plug from an old column to plug a gm into a ford painless harness.
Re: my green 68
Thanks tybob81,
Do you remember the part number you used?
I see they have a retro fit for our trucks.
Was yours a direct bolt up or did you have to modify anything other than the wiring.
TIA,Calvin
TIA,Calvin
- tybob81
Re: my green 68
Bolted right up an as far a a part number I can look....been over 5the years since I bought it.
