My 67 swb project... YES its finally started. Sub frame swap
- wt4speed#2
- GT-Racer
re: My 67 swb project... YES its finally started. Sub frame
I need lots of and even more
Drivin' a Chevy is Kinda Like wipin' before you poop, it just don't make no sense....
Well I am finally back. Had a little health problem and our local provider crapped, and I havent had internet for a month. Good to see your progress. Hope all is going good. I will try to add photos soon.
later
Bob
later
Bob
- customcrewcab
updates???????????????/
- GT-Racer
I know I know... I been gone a while. Just a whole lotta work hours and home projects.. I will try to be back on here more though.
Ok update...
The front sub swap is done. Well sort of. I notched the front cross member to allow the engine to set lower and avoid making new mounts. So as soon as the cross member is plated (boxed) back in it will be done. The engine is where it will be and bolts are in for now. Also found a BW t-10 from a Falcon. Side shifting close gears instead of granny 1st. That too is in and waiting for drive shaft measurements.
Next project will be a 4 link air ride rear. This one to be exact. http://www.truckshop.com/product.php?pr ... 340&page=1
Then a set of bags in the brand X front control arms and wallah riding on air. I cant wait.
Then the whole thing will come back apart for paint and final build.
Pictures as soon as I can. Good to be back!!!!!
Ok update...
- wt4speed#2
- GT-Racer
Gimmee email addresses? Truck shop offers 10 %discount over what Air ride list the stuff for. That was the best "package deal" I could find.
www.suicidedoors.com www.streetissuecustoms.com www.streetnshow.com (my favorite) www.gravity-werx.com just to name a few... you can do bags, link setup, brackets, tank
NONE of the pics show up anymore. Do you have them saved? If so pm me and I will give you my email address and you could just send them to me? Thanks
-Lance
-Lance
2015 Camaro-2001 GMC Safari-1984 F250 6.9/T19 2wd-1974 Dodge D100 short fleetside~ 72 wife ~ late model kids, a Chocolate Lab named Coco and a white rabbit named Marshmallow...now I need a ferret named Graham and I will have S'mroes!!!..
