Alan's 1967 Shortbed Stepside 4WD
Manny
Re: Alan's 1967 Shortbed Stepside 4WD
Post by Manny »
Looking great you are so close it looks like!!! :thup:
The Junk that hangs around
1974 Bronco 302 3 speed
1984 bronco 302 c6 35's
1994 F350 7.3 5spd dually.
popeyes71
Post by popeyes71 »
Good progress! I don't think there will be to many people with the same interior.
-Popeye-
1971 F-250 4x4 Highboy
67Step4WD
Post by 67Step4WD »
Thanks folks! Here's a pic of the seat installed. I wish I could find an original red steering wheel, I'm replacing the old worn one with a repro black one...
67 F100 SWB 4WD Custom Cab (In Progress)
1965 Lincoln Continental Convertible
1972 Fiat Spider
1963 MGA
1966 Chevy G10 NoDoor LS Swap
2006 Buell 900 Wide Rear, Chain Drive Short Track Geared
2013 Audi S4 Tuned
1965 Sunbeam Tiger
Way too many other projects.....
Opportunity is missed by most people because it is dressed in overalls and looks like work. -Thomas Edison
SMH1970
Post by SMH1970 »
Beautiful truck!!
Where did you get the 3pt seat belts, if you don't mind me asking.
- Steve
1970 F100 Sport Custom, 360 with 3 on-the-tree, No PS, no PB, no AC. Boxwood green / Wimbledon white.
Plans: power steering, power front disc brakes, clean and freshen from ground up.
67Step4WD
Post by 67Step4WD »
I bought the seatbelt kits from LMC. I've really tried not to use their stuff whenever possible, but my daughters will ride in this so I want 3 point belts.
1972 Fiat Spider
1963 MGA
2013 Audi S4 Tuned
1965 Sunbeam Tiger
SMH1970
Post by SMH1970 »
Thanks. Looks like the belts fit in there nicely, and belong there.
I want 3 point belts too, for the added safety.
- Steve
67Step4WD
Post by 67Step4WD »
A bit of progress: Bed came out to do the exhaust, wheels came back from powder so it's close: hub rebuild and trim and the dash, a bit more assembly shocks, etc. and it's done!
1972 Fiat Spider
1963 MGA
2013 Audi S4 Tuned
1965 Sunbeam Tiger
cdnwillyg
Post by cdnwillyg »
Looking good! :thup: :thup:
Stony Plain, Alberta, Canada
:drive:Willy
67Step4WD
Post by 67Step4WD »
Thanks!
1972 Fiat Spider
1963 MGA
2013 Audi S4 Tuned
1965 Sunbeam Tiger
DuckRyder
Post by DuckRyder »
It looks fantastic, this is in my top 5 favorite projects here for sure!
Nice work on the exhaust too!
Busboy
Post by Busboy »
Where did you source those exhaust hangar hook type deals?
1967 F-100 4x4 custom cab.
Manny
Post by Manny »
Man it all looks fantastic exhaust wheels tires she's a beauty!!! Tell us more about the exhaust. :?
Lone Ranger
Post by Lone Ranger »
What a great looking truck! Those tires and wheels are sweet, love the side mounted spare too.
Kyle
67Step4WD
Post by 67Step4WD »
the exhaust was bent/fabbed by a local shop. It's 304 stainless 16 gauge, with AP T304 stainless mufflers. This is a 4.9L, but I did put a ceramic-coated header on it that feeds 2 pipes, so I went with the dual pipes, but bent towards the ground at the end, I actually don't want them poking out, this isn't a hotrod after all. This isn't a cheap exhaust as it is meant to last forever, so I've got close to $600 in it!
The hangers are from good old Amazon, they are Walkers https://www.amazon.com/Walker-36516-Uni ... 2Y6H7DTDVY
The spare carrier is the original, as are the wheels but I put oversized tires on, so I can barely slide paper between the spare and the fender cut-out. The bracket is gonna have to be modified to move everything up 1/2 inch, so that'll take a small bit of figuring. i found some grade 8 Ubolts to go on the rear leafs, I'm trying to do everything I can grade 8 to limit corrosion. I have a repro black steering wheel, but I'm going to try paint and many layers of clear to see if I can get the original red wheel looking right and up to snuff in terms of usability.
****If anyone knows anybody with an original red dash pad in good shape I'd be forever indebted and probably lend you my truck my wife or my girlfriend*** In all seriousness please let me know!
1972 Fiat Spider
1963 MGA
2013 Audi S4 Tuned
1965 Sunbeam Tiger
Manny
Post by Manny »
Very complicated proposal there.. I will put my hunter on the red dash pad. That thing looks great. love this truck :thup:
