72 green explorer special
96 jag ranger
Re: 72 green explorer special
Post by 96 jag ranger »
As for sending a email I don't know about the headers so I have to pay some 100 to do it for me if duckryder will send me his email I can add it to my contacts then I can send him photos.
96 jag ranger
I just read that a 391 ft dist is bigger than a Fe dist just trying to fix a problem.
DisneysPatB
Post by DisneysPatB »
96 jag ranger wrote: Tue Mar 15, 2022 5:02 pm As for sending a email I don't know about the headers so I have to pay some 100 to do it for me if duckryder will send me his email I can add it to my contacts then I can send him photos.
http://fordification.com/forum/memberli ... email&u=12
1970 F250 460 C6 - Project - Currently not running.
1999 Dodge Durango SLT 4 x 4 5.9 Magnum -not running.
1999 Toyota Corolla - Daily Driver.
https://fordification.com/forum/app.php ... y/album/43
DisneysPatB
96 jag ranger wrote: Tue Mar 15, 2022 5:48 pm I just read that a 391 ft dist is bigger than a Fe dist just trying to fix a problem.
I think I may have found an answer to your problem(s).
96 jag ranger
You think that's funny .that's :bs:.you are supposed to be the expert why does this motor have ft parts .but you are a moderat er so you can do anything until want.
96 jag ranger
Instead of being insulting try helping.and answer the question why does this motor have ft parts.Is it a ft motor.
DuckRyder
Post by DuckRyder »
96 jag ranger wrote: Tue Mar 15, 2022 7:49 pm You think that's funny .that's :bs:.you are supposed to be the expert why does this motor have ft parts .but you are a moderat er so you can do anything until want.
Excuse me? I’m the only moderator presently here and I’ve done nothing but try to help you.
DisneysPatB
"How to find the right gasket for my engine?
The best idea is to find a gasket that is the right thickness and has a bore that is the closest to the actual bore of the engine without being smaller then the cylinder."
https://www.hotrodders.com/threads/head ... ze.147148/
Pretty sure @DuckRyder said that.
DisneysPatB
96 jag ranger wrote: Tue Mar 15, 2022 7:49 pm You think that's funny? That's :bs: You are supposed to be the expert why does this motor have ft parts? But you are a moderator, so you can do anything you want. (edited for spelling and punctuation)
First of all, I am not a moderator..... I will stop there? There are so many unanswered questions within your post. Clearly this motor has been put together in this fashion to benefit someone at one point. Why is it apart? When was the last time your truck was on the road or had a running engine in it?
96 jag ranger
What unanswered question s this is a 67 Merc colony park 410 bored .40 date code 7m7 with a iu crank with a ft intake and oil pump and dist this is as simple as it gets with a s intake that takes a ft dist.what other questions are there .
96 jag ranger
As for the 2020 gasket that is a 4.400 fit a motor with a bore of 4.090
96 jag ranger
The pan is still on the engine so I can't get a crank code or rod codes I have pictures of the old timing set and the timing cover but the photo issue is still the same.what other info is nessary.do you need what color on the ground.
DuckRyder
Post by DuckRyder »
96 jag ranger wrote: Tue Mar 15, 2022 5:00 pm Fine about the head gasket.but why does this motor have a 391 oil pump with the 5 sixteenth oil pump shaft and the 391 dist.and the intake that matches the 391 dist.anyone know the answer.also my new head's are a mismatch one is a c8aeh the other one is a c6ae I didn't know about the mismatch untill I opened the box es is that going to be a problem.thank you they look the same small ports and small valve chambers.
No idea why it has an FT distributor and oil pump, only answer I can give you is someone thought it was advantageous at some point. I personally would change it to FE stuff but it sounds like funds are not plentiful.
I will have to research the heads as I'm not familiar with C6AE you'll have to give me some time too, lot going on right now.
96 jag ranger wrote: Wed Mar 16, 2022 7:12 am What unanswered question s this is a 67 Merc colony park 410 bored .40 date code 7m7 with a iu crank with a ft intake and oil pump and dist this is as simple as it gets with a s intake that takes a ft dist.what other questions are there .
OK, well there you have it - lets put it together.
96 jag ranger wrote: Wed Mar 16, 2022 7:32 am As for the 2020 gasket that is a 4.400 fit a motor with a bore of 4.090
Yes. if you mean 1020.
I sent you an email from the board. Reply to it.
96 jag ranger
Don't know how to reply to the board .so am I in trouble.fine
96 jag ranger
T he other head is c6alu.
