Had a leaking head gasket, so I yanked her out to replace all top end gaskets, new ignition wires, coil, plugs, cap, rotor, and points. Also before I drop her back in im going to paint it. This was my first motor I took out by myself, and its going to be my first head gasket replacement. I just hope I dont screw anything up... Ill update when I finish.
new gaskets/ignition
- boots
Ethan
67 f100 - 4"lift - cut fenders - 36 TSL's
390/3spd/9"
68 f250 - 390/np435
Raised d24
'79 dana 60 front
welded 60 rear
buildup in progress
http://www.fordification.com/forum/view ... 835#136835
69 f100- Parts truck
390/3spd/9"
68 f250 - 390/np435
Raised d24
'79 dana 60 front
welded 60 rear
buildup in progress
- towens
- boots
I didnt get a complete set, just everything but distributor. The coil, pro MSD HEI cap and HEI wires were under 200.towens wrote:How much did that complete MSD ignition cost you?
Ethan
390/3spd/9"
68 f250 - 390/np435
Raised d24
'79 dana 60 front
welded 60 rear
buildup in progress
390/3spd/9"
68 f250 - 390/np435
Raised d24
'79 dana 60 front
welded 60 rear
buildup in progress
- heep70
Ahhh, you will do just fine. One thing to be anal about with the rear intake to block seal. They have a tendency to leak and sometimes bad. While tightening the intake keep checking that seal. Make sure it doesn't slip. After done take some extra sealent and smear it back there. I also smear a thin layer of sealer oround the water jackets holes on the intake gasket. Let it set up for a few minutes before putting the gasket on. Good luck, let us know.
Greg
2000 Subaru Outback limited.
2013 Polaris Pro 800 RMK 163"
My last 1971 "Highboy" pics
- boots
re: new gaskets/ignition
Got it put back together today. I had to send my Wires and coil back to JEGS because I want to use a HEI style pro cap, So they should send the new HEI wires and coil today, and ill get it on friday, when I drop the engine back in.
Ethan
390/3spd/9"
68 f250 - 390/np435
Raised d24
'79 dana 60 front
welded 60 rear
buildup in progress
390/3spd/9"
68 f250 - 390/np435
Raised d24
'79 dana 60 front
welded 60 rear
buildup in progress
- binder56jd
that painted up real nice - good job
now serving #235
now serving #235
- boots
Put the engine in yesterday, today I spent some time putting it together, I have to hook up the clutch pedal linkage, then bolt up radiator, add fluids and then get my coils and wires from jegs.
Ethan
390/3spd/9"
68 f250 - 390/np435
Raised d24
'79 dana 60 front
welded 60 rear
buildup in progress
390/3spd/9"
68 f250 - 390/np435
Raised d24
'79 dana 60 front
welded 60 rear
buildup in progress
- 390Nut
Got a part # for that cap setup?
Enquiring minds want to know...
`69 F100 390 4spd driver
- boots
Re: re: new gaskets/ignition
heres a link to jegs, http://www.jegs.com/webapp/wcs/stores/s ... ryId=11565390Nut wrote:Got a part # for that cap setup?
121-8414
Ethan
390/3spd/9"
68 f250 - 390/np435
Raised d24
'79 dana 60 front
welded 60 rear
buildup in progress
390/3spd/9"
68 f250 - 390/np435
Raised d24
'79 dana 60 front
welded 60 rear
buildup in progress
