I live in the Netherlands and have '71 302 cid F100 custom 2 wheeler.... since the shifting is sloppy, i'm planning to completly rebuilt the manual column shifter
i'm starting off with the transmission control selector lever socket and the column gear shift lever insulator... couldn't get a new gear shift lever so i'm using the old one but will replace the gear shift lever impact seal
then replacing the gear shift tube and finally all the way down to the bottom replacing the two column shift lever arms + the 3 nylon washers that seperate the two shift arms + some new shift arm clips
so... has anyone ever gone thru this rebuilding proces ??... is it hard to do ??
anything i should well be aware off ?? (i hear is difficult to get the shift tube back in) ....and do you need to fine tune the adjustment at the tranny ??
how is that done the best way ??
Thanks
John
