Neutral Safety Switch
1970pickup
Post by 1970pickup »
I am swapping an automatic in place of the three speed in my 1970 P/U. The steering column has a neutral safety switch which has a pigtail with a plug. Does my stick shift truck have a provision in the harness to plug this in or will I have to rewire. Any help appreciated !
Jack
flyboy2610
re: Neutral Safety Switch
Post by flyboy2610 »
This post might help answer some of your questions.
http://www.fordification.com/forum/view ... ety+switch
Welcome to the site, by the way!
Stop by the Welcome Mat and tell us about yourself. Post some pics of your truck if you have any. We love pics! :hi:
Leadfoot
Post by Leadfoot »
You don't need to hook it up just make sure you are in park/neutral when you start the truck. also if you stall at a stop sign its nice to be able to start in gear. :shh:
but if you want to hook it up you splice in to the red wire with a blue stripe. switch in the middle. And for back up lights you need to find the black wire with a red stripe in a 3 speed its normally goes to the trans so you will need to pull the wires back up in to the cab and link it to the safety switch (black wires with a red line)
WHAT ?
