has anybody made a coil cutoff swtich, or something else, anti-theft related?
i am thinking about splicing my coil and running a switch to underneath my dash, so i can flip it and my coil will not produce spark.
coil cutoff switch
- splavin90
coil cutoff switch
69 F100 81' 302 / 73' fmx
I'd rather go hunting with Dick Cheney than go driving with Kennedy
- theskytoucher
- 72hiboy4x4
if you splice a wire from the negative side of the coil, thru a hidden switch, then run it to ground, it will stop the points from sparking - without having to worry about 12vdc positive shorting anything out.
- jor
Years ago I installed a few of those coil cutoffs for friends. It's a pretty good anti-theft device that costs little. I remember installing one so it activated with the ash tray. To start the car, the owner just pulled the ashtray out and that enabled the coil by flipping a toggle switch.
I'm with Customs and we come across a lot of pretty inventive electrically controlled compartments for smuggling dope. Typically, they involve several actions (e.g. pull this knob, turn this switch) and voila! a side panel miraculously pops open!
jor
jor
- 67highboy
I have one on my truck. I put it right down by the E-brake release handle and wired it just like Highboy said, using a ground circuit.
It works well.
Its funny when one of your friends or family tries to move it when your not around, when you get home they allways have a very serious look on their face and say "Dude, Your truck wont run... BUT I DIDN"T DO ANYTHING TO IT I SWEAR"
It works well.
People who are willing to give up essential liberty to purchase temporary safety, deserve neither liberty or safety...
Ben Franklin 1775
Ben Franklin 1775
- Dropped 68
I had one in mine, but it wasn't for anti theft purposes. It was a (re-route the grounding to the engine coil, to the coils in the back, thus causing the engine to spit lots of unburned fuel through the exhaust back to the now being ignited spark plugs in the tips). Kind of deal, and of course, I used a three position toggle switch. Sadly my truck slipped out of park on a hill, and mangled one of my tailpipes. (July 4) So I currently don't have my flame throwers, but once I get some free cash to get the exhaust fixed. I'll be roasting once again.
Charles
http://www.fordification.com/galleries/ ... ?cat=10451
http://s111.photobucket.com/albums/n146 ... =#imgAnch1
Build, Destroy, Rebuild!
- splavin90
67highboy wrote:I have one on my truck. I put it right down by the E-brake release handle and wired it just like Highboy said, using a ground circuit.
It works well.
i am going to do that to one of my friends, throw them the keys to my truck and be like WTF YOU BROKE IT!
