AC install
AC install
I hope someone here has the information I need. I am putting a factory AC in my 77. I have everthing figured out and installed except two wires. Under the dash there are 3 wires that come through the middle of the blower box. One goes to the compressor clutch and I think one goes to the original heater blower connector on the wiring harness but where does the other go? The one to the blower connection is not the correct type of connector so I guess I have to make a change there. The left over one is a little short but maybe it is intended to go to the carb? Anyone have any ideas or poctures? Thanks.
77 F-100 Work In Progress - My Son wants it to be black with flames
- flyboy2610
re: AC install
Ground?
Re: re: AC install
That's a great question!flyboy2610 wrote:Ground?
re: AC install
No the ground wire I figured out. There is a large round spade on it and I still have two wires left over.
re: AC install
can you post some pics of what you have? i have a wiring harness from a 78 that i parted out. i might be able to figure it out if you have some pics.or at the least what colors were they and where exactly do they come and go from through the firewall? or just under the dash?
- Fake Name
re: AC install
Guessing here- I think the carb might be correct. Many AC installations have a small throttle positioning solenoid that kicks up the idle to compensate for the increased load on the engine.
That typed, I'm assuming it's not the wire to the compressor, right?
fn
fn
re: AC install
No the wire to the compressor is prety obvious. It is long and plugs right in. I just have the two wires left that I don't know where to plug. I will take some pictures of it tommorow and put them in if I can.
