Interior Lighting issues
- 71PA_Highboy
I have no dome light and no heater control light.
The dome light does not have 12V... what is the routing for the dome light wire?
The heater control light has 12V, but is missing the light socket... anyone have a spare?
TIA
Eric
TIA
Eric
Got Ford?
2 EarlyBroncos (68,69)
2 Classic Mustangs (69,70)
1 94 Ranger, 2.3, 5spd
1 Lincoln Mark VIII
1 Lincoln Mark VIII
- rjewkes
the dome runs off the cigar lighter fuse check that fuse. also might check the doort switches.
- 71PA_Highboy
No door jamb switches.... or brackets... trying to find some but no luck yet...rjewkes wrote:the dome runs off the cigar lighter fuse check that fuse. also might check the doort switches.
Any idea the path the wire takes from the dash to the dome light?
Thanks!
Got Ford?
1 Lincoln Mark VIII
1 Lincoln Mark VIII
- rjewkes
to work with the doors open they need the jamb switch. have you tried with the headlight switch twisted all the way to the drivers side?
it could even be th rehostat(dash dimmer switch.
- kknip
re: Interior Lighting issues
Soitenly! Oh,a wiseguy!
You knucklehead!
![Image](http://upload7.postimage.org/222426/3gears.jpg)
65 Mustang
72 F250 Camper Special
You knucklehead!
65 Mustang
- 71PA_Highboy
rjewkes wrote:to work with the doors open they need the jamb switch. have you tried with the headlight switch twisted all the way to the drivers side?
Uhhh... no... the rheostat does not control the dome light... the rotation of the headlight knob does engage the dome light, but the rheostat is not part of that circuit.
And yes, I had it turned... (but I did double check just to make sure....)
I think it is the wiring behind the dash... probably disconnected...
Thanks.
Eric
Got Ford?
1 Lincoln Mark VIII
1 Lincoln Mark VIII
- rjewkes
I stand corrected on that part. Now i know.
It is still the same fuse for the lighter as the dome.
- 71PA_Highboy
Thanks for all the advice... In my junk pile I found an old mustang harness that had one of the light sockets... put a bullet conenctor on it and Voila! Lights in the heater control.
Swapped the Cigar lighter fuse... Dome light works now...
LET THERE BE LIGHT!
Thanks again all!
Eric
LET THERE BE LIGHT!
Thanks again all!
Eric
fordman wrote:oh and yes i have a dash light for the heater controls. i had to look and see. but i do have one.
Got Ford?
1 Lincoln Mark VIII
1 Lincoln Mark VIII
- 19674x4
the dome light is supposed to come on when i open the door?????
uh oh not good.
uh oh not good.
My Photo Album
