Ok i got some leds and it appears that regardless the number of LEDS on the Parking/Running lights they all light up. But when i put two leds in on the same side left/ right Turn signals don't work on the side with two leds.
Wich will work better with the 67-72 f series, the Load eqaulizers or an electronic Flasher Fuse?
The package at autozone for the led equalizers says the have to be run so close to the bulb and an inch away from the runing light wire and have plenty of air. I don't think plenty of air will be getting to the equalizer becuase its back there in that end cap on the bed.
if i have to i can run only LEDS in the back and Normal 1157's upfront.
LED Load leveler or turn signal Flasher fuse?
- rjewkes
- ICEMAN6166
re: LED Load leveler or turn signal Flasher fuse?
i would use the flasher as its going to plug in to your harness inside where its not in the end cap of the bed.there was something else posted on this recently.
- rjewkes
cool. I'll look for one at the local parts place.
