I have a charging prob that may cause a divorce.
I disconnect the neg. batt. cable, put the pos. clip on my volt meter to the grd cable end, and the neg. clip on the grd post, I show a 7 volt pos reading which means I have a short somewhere. Right?
The problem seems to be the wire with the fuseable link from the starter solenoid (battery side) to the batt post on the alt. It also splits off in the middle with a yellow wire to the "A" side of the volt reg. It ohmed out good but I'm considering replacing it anyway. Does it have to be a fuseable link or can it be a straight wire?
Also, it show3s to be charging by shorting from the alt to the batt but without the jumper wire, it is not charging the batt.
I hope someone can help here or post a pic of their wiring in that area.
