Hey all, I replaced my clutch on the 67 f-100 w/300 about 2 years ago. It has since been grabby, rough, heavy, just garbage. The flywheel was resurfaced and a new rind added. The clutch is a Borg Warner diaphram. This engine has an odd vibration wich is the biggest problem About a month ago I replaced the clutch on my 69 w/360. I replaced it with a Sach's 3 finger unit and same fly wheel treatment.
The 67 clutch is garbage, the 69 is super easly and smooth. The 69 has the original linkages and the 67 has all new parts.
The 67 has a 1992 (300) engine with the 67 flywheel. I still have the 92 flywheel. Could the 67 flywheel on th 92 engine cause the vibration? Is the Borg warner cluth just that junky?
Nick
Odd Clutch Questions
- FoMoCo
1969 F-100
2006 Fusion SEL
2006 e-320 cdi
2004 excursion V-10
2006 Fusion SEL
2006 e-320 cdi
2004 excursion V-10
re: Odd Clutch Questions
Not sure but i think they changed the balacne method somewhere in the early 80s so you enging could be out of balance. Would cause a nasty vibration.
- MadMaxetc
Check over at www.Fordsix.com. I am almost positive that they whent from External to Internal balance.
(WHOOOO 250 posts!! 2 Stars for me!!)
Dan
FORD Girl
Photobucket Pictures
FORD Girl
- FoMoCo
ARGH! I have gone off the deep end over this engine vibration for years now. I have tryed timing and going over the balancer a million times. I just happend to keep the old fly wheel to have an anvil.
Nick
Nick
1969 F-100
2006 Fusion SEL
2006 e-320 cdi
2004 excursion V-10
2006 Fusion SEL
2006 e-320 cdi
2004 excursion V-10
- FoMoCo
That's what I was leaning towards. The engine is a 92 block, internals, and a 240 head and flywheel. I bought a 92 clutch wich happend to be a diaphram style. When I replaced the clutch on my 69 w/360 I bouht the 3 finger type and there is no comparison in the ease and smoothness of the 3 finger. I guess I should get the 92 clutch surfaced and a 3 finger.
Nick
Nick
1969 F-100
2006 Fusion SEL
2006 e-320 cdi
2004 excursion V-10
2006 Fusion SEL
2006 e-320 cdi
2004 excursion V-10
- 390Nut
A good working, properly mounted Diaphragm clutch will be twice as smooth as a Long style clutch any day of the week, including ease of pedal travel. It's inherent in the design of the Diaphragm style clutch.
![Image](http://img.photobucket.com/albums/v169/FrayedSanity/ford1.gif)
`69 F100 390 4spd driver
Pipes71 did once say, "bumps and bikes.. what a great combo!"![Thumbs up :thup:](./images/smilies/icon_thumright.gif)
