Just wondering if I'd noticed much of a difference between the 3.25 gear currently in my ford 9" verses going to a 3.50 or 3.73?
I've got the 306 humming now and it's a jet above 20mph but I'd like a little more pull from a stop.
Not dragging, not pulling, mostly city miles.
Thanks
Noticeable difference?
- 69rangerman
"O say, does that star spangled banner yet wave? Oer the land of the free and the home of the brave?" It does at my house! God bless America!
- FoMoCo
re: Noticeable difference?
I Have a Ford TOD trans in both trucks, same size tires and such. I notice a difference between my 3.73 and 3.50 gears. I would rather have the 3.73 for general driving around, and light hauling/towing.
Nick
Nick
1969 F-100
2006 Fusion SEL
2006 e-320 cdi
2004 excursion V-10
2006 Fusion SEL
2006 e-320 cdi
2004 excursion V-10
- MadMaxetc
3.25 to 3.50 would be a 7.7% reduction. So 2000 RPM would become 2154 RPM.
3.25 to 3.70 would be a 13.85% reduction. So 2000 RPM would become 2277 RPM.
With the 3.70 you will notice a lot, probable mostly in the pocket book (gas $$).
The 3.50 I think would be a good comprimise.
My![2 cents :2cents:](./images/smilies/icon_2cents.gif)
My
Dan
FORD Girl
Photobucket Pictures
FORD Girl
- 390Nut
Definitely a noticeable difference, especially going from 3.25 to a 3.73. I went from a 3.25 to a 3.50 and noticed quite the difference in acceleration, especially on the bottom end. Don't need to rev it as much as you let the clutch out to keep it from bogging, and off the line acceleration is improved a lot.
If you're seeking mileage, stick with the lower numbers. If you're looking for a little more excitement, bump it to the 3.50. You can tow with the 3.50's, but I wouldn't try hauling frequently heavy loads with them. Just remember the higher the number of rear gear, the higher the RPM's to sustain the same speed. I use to cruise 60mph at about 2400 with the 3.25's, with the 3.50's it's closer to 2700RPM.
![Image](http://img.photobucket.com/albums/v169/FrayedSanity/ford1.gif)
`69 F100 390 4spd driver
Pipes71 did once say, "bumps and bikes.. what a great combo!"![Thumbs up :thup:](./images/smilies/icon_thumright.gif)
- 69rangerman
Thanks guys. Since it's finally back on the road for DD status I don't want to open anything I don't have to back up, but wanted to know for later.
I appreciate the advice.
Tom
Tom
