3 spd clutch/pressure plate assembly.
layedout72
Post by layedout72 »
Okay, so I didn't take enough notes when pulling everything apart. So I am here wondering which side of the clutch, faces the pressure plate, and which side goes away from it. The one side (that I believe is the side to face the pressure plate) has the springs pushed out from the actual disc about a 1/2 inch. The other side is flush with the actual disc. Am I thinking right that the part that is "pushed out" faces TOWARDS to the pressure plate?
layedout72
re: 3 spd clutch/pressure plate assembly.
like this.
Jake11
Post by Jake11 »
The flat side goes toward the engine.
layedout72
okay, so I have it right. haha. good stuff. Tranny should be slid in tomorrow, and hopefully the motor goes in before lunch! Should be a good day.
Jake11
Post by Jake11 »
Put a little grease on the tranny splines the disk rides on, the tube the
throwout bearing rides on, the end of the shaft that goes in the crank.
Good luck 8)
jor
Post by jor »
Emphasis on little.
jor
Jake11
Post by Jake11 »
A light film. :wink:
