C6 linkage
Heavenlyfire
C6 linkage
Post by Heavenlyfire »
Will the tranny linkage from a dentside fit a bumpside? Both big block engines.
AlleyCat
re: C6 linkage
Post by AlleyCat »
I'm in process of dismanteling a 76 F250 CS that had a 390.Linkage looks the same as my 72 F100.Hope this helps. :)
Clay
FORDification
Site & Forum Admin
Site & Forum Admin
re: C6 linkage
Post by FORDification »
I don't see why it wouldn't....the frame's the same, the engine/tranny are the same, the steering column is (basically) the same. I see no reason why they wouldn't interchange.
I CAN tell you that the linkage for the '78-'79 trucks is different though. The neutral safety switch is moved from the base of the steering column down to the side of the transmission, so the linkage for those years is different to accomodate the NSS.
Heavenlyfire
re: C6 linkage
Thank you both :thup:
