The great intake swap.(legnthy w/pics)
wt4speed#2
Post by wt4speed#2 »
As some of you know my "2nd time 'round" project turned in to a garage clutter piece,as of late. It's not that I've let her die on the vine . After a 6 month bout with unemployment (no comp. pay approve)and health concerns that left me pretty dang useless ,this was the main reason for length of unemployment (no workers comp. claim either).
With the new job and the heat my level of entusiasum has been a little less than stellar.
When I started down time on this project , I wasn't on a time frame as my employer furnished my DD (2007 Ford F-250 s/d 4 door :cry: ) . I was forced to try to get her back on the road as secondary transportation for the family. Know I had quite a bit of repair work on the cab ,I had been muttling thur it . When the U hit I started scrambling . I was trying to fix the worse cancer affected areas i.e floor pans ect. "Well while I was there" <hehehe>
I have acquired several upgrade and future adds for my truck. Most of which are now backburner stuff due to time constraints. have a lot of repairs to do to make this cab useable I was fixin at 'em and try to get my money tree to sprout , to fund a cab. A "hippy" angel appeared , quizzed me as to how much I was having to fix,I told him showing as I explained. He told me that if I wasn't YOM restrained(a big way of asking if it had to be a '69 cab) he had a '70 cab that don't need much. All he want's is my cab for core weight. Thanks "bro" you know who you are. So now That shortens my list a ton. just gonna prime the interior so I aint sitting in the dark. During the down time I've lowered it , tires and wheels , headers , carburetor man waco tx 'factory spec. reman holley . And then the back burner stuff.
Another member hooked me up with an 'offenhuaser 360* dual plane 351w aluminum intake (did get a before pic dang). Was gonna wait but the clean up turned out great. With some brainpicking of Mike(fitzwell)
I decided to do the intake swap as I had the reman. Holley feeding a factory 351 w 2v intake thur a 2x4 adapter plate. I've enlisted Mikes help and plan to at least fire and tune her next week. Was gonna try for sunday afternoon (may still). but got side tracked . After fitz and I get her cranked and tuned , I've got to get the tins hung back , Rig up some rear temp. fenders( bed ain't no where near ready). I'm gonna drive it while I groom the other cab, paint the cab , doors fenders and hood ( one at a time ) . Then I'll be back to a cab and chassis ,while i go thur the bed. Sounds like pipe dreams i know but this is my goal.
Sorry so long a few intake pic more to come later:
Looking for a new home.
test fit....
'offenwhat :hmm:
reman carb
Image[/img]
Tony B.Image
DFW Area
"Someday...
I hope you to get the chance,
to live like you are dying"
Member#'s 236 & 403
Úlf the Comedy Sidekick
'69 F-100 "Stepper"(currently in a bigillion pieces )
wt's ride
thebucket
ezernut9mm
re: The great intake swap.(legnthy w/pics)
Post by ezernut9mm »
they're only pipe dreams if you don't act on them and it looks like you're doin' it to it! lol. lookin' good man. :thup:
Thunderfoot
Post by Thunderfoot »
Looks good so far Tony :thup: looking forwards to more picts :pop: :P
Shayne
dablack00
Post by dablack00 »
Keep going.... We need more pics.
two-bit
Post by two-bit »
:pop: :pop:
flyboy2610
Post by flyboy2610 »
I have that same manifold for a 390. I plan to use it when I do the rebuild. Gonna put a 4bbl Holley on it. Make sure you post as to how well it performs. I'd be real interested in that.
wt4speed#2
flyboy2610 wrote:I have that same manifold for a 390. I plan to use it when I do the rebuild. Gonna put a 4bbl Holley on it. Make sure you post as to how well it performs. I'd be real interested in that.
TTT
Well flyboy I'll let you know I really don't have much to compare it too as she ain't seen fuel in over 2 yrs but i'll bet i'll be thrilled. With any luck I'm gona try to get her at at least started sunday sometime. In the middle pic the heater hose connection gave me some problems ad i stripped out about 5-6 aluminum threads removing it . it was clogged and , it's replacement will look somewhat different not as pretty but functional .
more pics by sunday i promise
Tony B.Image
DFW Area
"Someday...
Member#'s 236 & 403
wt's ride
thebucket
wt4speed#2
re: The great intake swap.(legnthy new pics)
All torqed down
Here is where the threads came out
Ant this is the Spacer I have decided on .
Tony B.Image
DFW Area
"Someday...
Member#'s 236 & 403
wt's ride
thebucket
wt4speed#2
Tying up some loose ends
Passenger side loose ends
After she ran pretty high idle for about 10 minutes
If you look real close you can see the burnt header paint
Tony B.Image
DFW Area
"Someday...
Member#'s 236 & 403
wt's ride
thebucket
mjhaltom
Post by mjhaltom »
I like rust-red headers! I might as well, the all end up that way!
2015 lifted Toyota tundra 4.6 4wd
2002 Toyota Sequoia 2wd 4.7 auto
1989 Ford F150
1979 Chevrolet C10 350/TH400 14 bolt "Big 10" (DD)
1972 F100 parts truck long bed
1971 F100 2WD LWB 302 aod 3.70 9inch PS pb
1966 International Scout 800
1954 GMC rat rod project Scout frame, inline 6, T90 4X4
1953 Chevrolet Tin Woody
1946 Hudson BigBoy Pickup-ratrod project
