I changed the gear oil on my T18 about 2 weeks ago. I noticed that the oil that came out was at least a quart less than was supposed to have been in there; now I've found out why. It's leaking like crazy!
I know this picture is somewhat dark, but you can see the shiny area on the bottom of the transmission case where it is slick with brand new golden brown gear oil.
It's not leaking at all by the output shaft. I can't quite tell if it's the side access door or the input shaft that's leaking, I think it's unlikely to be the input shaft from where I'm finding the oil:
I keep finding oil where the red oval mark is. What is this plate on the side of the transmission for? Is there a gasket I can replace here? It doesn't look like there's any gasket material there right now, maybe that's the source of the problem?
Thanks for the help, guys!
