302 swap in help...
sgt_fixit
302 swap in help...
Post by sgt_fixit »
need help... dropping a 95 roller rocker 302 (miustang 5 spd original) in place of the original 302. WILL BE USING original 3 spd manual. need to know if my original flywheel should be used, or the flywheel off the 95... or do I have to go buy another (50 oz, 157 tooth???)one? I've been told all three and really can't afford to buy more parts. :?
Thanx... sgt_fixit
AustinTom
Post by AustinTom »
Use the flywheel off of the 95
69 F-100 lwb 240 Np435
95 F-150 lwb 4x4
http://s110.photobucket.com/albums/n85/ ... type=local
ima71 trucks are older
Post by ima71 trucks are older »
you have to use the 50oz '95 flywheel. measure its diameter againt your current truck one. truck belhousings used you use a larger flywheel then car belhousings, not sure if it was still true in the mid 90's
68 F100 soon to be on an 80's 4x4 frame and 300-4spd
69 F100 300-4spd
78 F150 300-3spdOD
