I'm getting my '71 ready for a daily driver. Hoping to have it ready to drive in the next 2 days, so I've been going through the problems I need to fix.
I've got this strange growl coming through the drivetrain. Not sure where its coming from. My first thought was it was low or no oil in either the rear end or tranny, but they're both full at just below the plug.
Any idea where this could be coming from? Any inherent weaknesses in these drivetrains that might cause a growl?
Symptoms are that its especially loud in reverse, but its loud enough that in third gear at a moderate speed the growl is about the same noise level as the exhaust. Its hard to track down where its coming from as sounds travel up and down the driveline so easily.
Any ideas?
Growl in the drivetrain
- Wes
Check for rusty/stiff u joints, is two piece shaft may be center support bearing. May have to run it on jack stands
and listen with stethoscope.
Wes
67 F250 High boy
69 Bronco
67 F250 High boy
69 Bronco
- lightning_msd
re: Growl in the drivetrain
i had a bad growl in my 79 a while back, turned out it was an axle bearing, u joints usually have a knock when there shot, the centre bearing you would feel a bad vibration, so its probably a bearing somewhere in either your axle or your front end ![2 cents :2cents:](./images/smilies/icon_2cents.gif)
1967 F100 "Lexxi" 352
http://www.fordification.com/galleries/ ... ?album=482
It doesnt have that trademark "CHUNK" when goosing it that a u-joint always seems to have. Thats what made me disregard the u-joint.
Carrier bearing, (center bearing for the 2 piece driveline) seems tight, no play at all.
Guess I'm going to have to buy a mechanics stethascope and try the jackstand method.
- Vinniesempire
The "CHUNK" you're referring to is when the needle bearings are completely gone. However, they could still be still present and just very worn and dry, so there's not enough play to cause the CHUNK sound, but enough to cause the noises you're hearing.Ripsnorter wrote:It doesnt have that trademark "CHUNK" when goosing it that a u-joint always seems to have. Thats what made me disregard the u-joint....
I vote for checking the U-joints. It's been my experience that nine times out of ten it's always the easy things to fix, and the problem is usually whatever it was you chose to disregard during the diagnosis.
![Wink ;)](./images/smilies/icon_wink.gif)
thanks guys, a lot of genuinely helpful advice here.
I live out between chehalis and kelso/longview on I-5 Paul. Probably a bit of a drive for you if you live on the coast. I'm also not sure if I'm going to get to it this weekend. (fingers crossed) I've got this '47 plymouth that I'm coming to loathe that I need to get out the door before I can get anything else done. Would be nice to meet you though.
- 390Nut
Actually, I put that there because all of western Washington is a "wet coast"
I'm in Shelton, probably an hour or so away.![Cool 8)](./images/smilies/icon_cool.gif)
![Image](http://img.photobucket.com/albums/v169/FrayedSanity/ford1.gif)
`69 F100 390 4spd driver
Pipes71 did once say, "bumps and bikes.. what a great combo!"![Thumbs up :thup:](./images/smilies/icon_thumright.gif)
- lightning_msd
AHHAAAA!!!! I KNEW IT WAS A WHEEL BEARING (not fordified for nothin ya know
![Razz :P](./images/smilies/icon_razz.gif)
