5-speed tranny questions
- 71Ford100
What, if any, FORD 5 speed trannys will bolt to either the 360/90/428 block and the 429/460 block. Also tranny needs to either bolt up to a dana 24 or a np205 perferably the 24.
Lance Peters
'72 250 4x4 project,''71 F-100 daily driver,69 F-250 4x4 Crew, '68 F-100, '68 F-250 crew under restoration, '52 Dodge 1/2 ton overload, gazillion tractors and combines
- AustinTom
- AustinTom
- 71Ford100
re: 5-speed tranny questions
What is the spline count on the outpoint shaft of the t-case on the 205?
Lance Peters
- AustinTom
- averagef250
All ford NP205 output yoke splines are 32 spline. All Ford fullsize t-case except the Dana 21 are 31 spline from 73-97. All 73-97 Ford fullsize transfer cases interchange.
The S5-42 460 gas version bolts to an 385 engine and a 205. It will not bolt to an FE.
- 71PA_Highboy
Not only will it not bolt to an FE, NO ONE makes an adapter....
yet...
eric
yet...
eric
Got Ford?
2 EarlyBroncos (68,69)
2 Classic Mustangs (69,70)
1 94 Ranger, 2.3, 5spd
1 Lincoln Mark VIII
1 Lincoln Mark VIII
