69 tranny fluid change?
Is it this easy?
1- drop the pan and let the fluid drain out.
2- clean off pan and tranny.
3- put some gasket sealer and a new gasket on....
4 replace bolts............
Or am I missing something? I am really new to this old truck stuff, and you all seem to really know your stuff! I need all the help I can get. Should I let a shop do the fluid change............. Or is it something a guy like me with little skills can accomplish? Thanks for any help I can get!
- Finleyphoto
re: 69 tranny fluid change?
Change the filter or screen.
Dennis
Dennis
- basketcase0302
04stangman,
What tranny model?
Some fords had a ball bearing, (I believe some kind of check valve) above the filter. When you dropped the filter it came out, (don't lose it if you have this).![Crying :cry:](./images/smilies/icon_cry.gif)
Some of Ford's four-wheel drive C-4's also had a short tube/pipe that ran through the filter, (if you got it make sure you put it back in).
Definately change the filter for sure.
Hope this helps.
Basketcase
What tranny model?
Hope this helps.
Basketcase
I wouldn't use gasket sealer, go out and buy a good gasket(not the cork stuff) and you not need sealer. With a good gasket the bolt holes hold some of the bolt so you can hold the pan and put them in. So what basketcase said be careful when pulling out the filter.
Kyle
Kyle
![Image](http://www.fordification.com/images/forum/th_70front.jpg)
![Image](http://www.fordification.com/images/forum/th_three3.jpg)
![Image](http://i222.photobucket.com/albums/dd207/truckguy_02/000_0675.jpg)
1986 F-150 300
1972 f-250 360 PS,PB
1970 F-350 360 PB
1969 f-250 390 CS,ranger, PS,PDB,AC
1968 F-350 360 PB
1968 f-250 360 PB
http://s222.photobucket.com/albums/dd207/truckguy_02/
Re: re: 69 tranny fluid change?
Supposedly I have the C-6, thats what came stock. Hum, Now I am not sure if I want to try it my self?basketcase0302 wrote:04stangman,
What tranny model?
Hope this helps.
Basketcase
Its not hard to do. I think that you can to it. Is there something wrong with the fluid or just wanting to change it.
Kyle
Kyle
1986 F-150 300
1970 F-350 360 PB
1968 F-350 360 PB
1968 f-250 360 PB
I see, are the bolts lose. I check that first and if not, then it needs a gasket.
Kyle
Kyle
1986 F-150 300
1970 F-350 360 PB
1968 F-350 360 PB
1968 f-250 360 PB
- basketcase0302
04stangman,
Not really that hard to do, (sorry, I didn't mean for it to sound like it was).
If you can afford it, a nice thing for the future is one of these.
http://store.summitracing.com/partdetai ... toview=sku
If your pan is leaking around the bolts, chances are someone has over-torqued the bolts and distorted the flange/lip of the pan.
It sucks to get the pan off and find it's not flat anymore, (yeah, you can peen it flat again but take a chance on it still leaking)?
Basketcase
![Doh :doh:](./images/smilies/icon_doh.gif)
Basketcase
- 69rangerman
If the pan is warped you can get a large 8-10 inch file and flatten it back out if it's not too bad. While it's out, go and buy a 1.50 drain plug and install it by drilling a hole in the deep part of the pan (make sure it won't hit anything when you re-install the pan). It makes future drains a snap.
"O say, does that star spangled banner yet wave? Oer the land of the free and the home of the brave?" It does at my house! God bless America!
Here's a shot of the torque converter drain on the C6 behind my 460. It'll look similar to this:04stangman wrote:fordman wrote:you will also want to drain the toruqe converter to do a full fluid change. the converter has a square bolt in the front of it to drain it.
Do you have a picture or directions to this part? I have no idea what that is?
![Image](http://www.fordification.com/board/torqueconverter-drain.jpg)
I took this shot when I was documenting removal of the rounded-off flexplate nut....that's why it's all boogered-up.
