Pilot bearing?
Pilot bearing?
Is there a tool I could maybe rent from the local parts store to remove the clutch pilot bearing in my 67? If not what do ya guys recommend I do to get it out?
Camel Ciggarettes,John Deere and Ford "Hard To Beat"!!!!
re: Pilot bearing?
Autozone has the tool and the slide hammer in their loaner tool program. However, you don't necessarily have to have a pilot bearing puller to get the the bushing out. Pack the pilot bearing hole with a heavy wheel-bearing grease, then take a bolt that is as tight to the ID of the bearing as possible, then drive the bolt into the greased up center of the bearing. The hydraulic pressure usually pushes them out, but if it doesn't come out the first time, repack the pilot bearing hole and repeat until the pilot bearing is free. The process is kinda messy, but it's free!
Then just clean out all of the grease and install a new pilot bearing.
- craftsman
This is what i use. It has worked for me for 3 times so for, i know it's cheep but if you are gental and take your time don't over torque it, it will work fine.
http://www.harborfreight.com/cpi/ctaf/d ... umber=4876
re: Pilot bearing?
Thanks for the help guys. I will give the FREE method a shot first and if that dont work Ill run down to Harbor Frieght or Auto Zone. Thanks Again.
- heep70
Grease method worked for me a few times so far. I used a wooded dowel.
Greg
2000 Subaru Outback limited.
2013 Polaris Pro 800 RMK 163"
My last 1971 "Highboy" pics
- AlleyCat
re: Pilot bearing?
Another vote for the grease method.My dad showed me that one when I was a kid.I use an old input shaft.It will R & R then bearing and align the disc.I like freebee tools. ![Smile :)](./images/smilies/icon_smile.gif)
Clay
re: Pilot bearing?
i have also used the hydraulic method many times and it has always worked. it can get a little aggravating but it will work.
