flywheel bolts?
flywheel bolts?
I recentley took off the 3 speed in my 67 to install a c4 automatic. I took the pilot bearing off and installed the new fly wheel as well. Are the six bolts that run through the flywheel longer in the 3 speed than the automatic bolts? They seem to be a little longer. Anyone had this problem before?
Camel Ciggarettes,John Deere and Ford "Hard To Beat"!!!!
re: flywheel bolts?
So if Im not mistaken the bolts I have now are 1" and I should be looking for 3/4"??
If so anyone know a good place to find um. I been to a few auto part stores but no luck.
re: flywheel bolts?
I'm not sure on this, but is it a preferred method to use locktite on flywheel bolts?
re: flywheel bolts?
The engine is an in line 6 240
re: flywheel bolts?
I belive the last set I got for a six were the same a a sb. and around hear going to the autowrecker for such a thing is a wast of time, I would not send a guy in the yard for bolts. so you could go to a ford dealer, or APR/ or even trans dapt, or motormite. will have them and you local parts store should be able to order them for you.
and yes most people do use some sort of thread lock
WHAT ?
- FORD428CJ
Re: re: flywheel bolts?
If it is an FE, you don't need to worry about sealing the bolts. If it is a SBF, inline 6's, 6.9, 7.3 Diesels then you need to seal them off or you will have a leak on your hands. I use liquid Teflon to seal them up with, from Permatex.Banjo wrote:I'm not sure on this, but is it a preferred method to use locktite on flywheel bolts?
Here it is:
http://tinyurl.com/24gsde
Wes Adams FORD428CJ
Built Ford Tuff With Good Ford Stuff
79 F-250 X-Cab 4x4 6.9 Turbo Diesel
64 Falcon X-Ram 428
55 FORD Truck 4-link Rides on air with X-Ram 428
67 Stang 351 C/J
2000 Yamaha V-MAX VMOA#4277
64 Falcon X-Ram 428
67 Stang 351 C/J
