TV cable ?
shortbedCUSTOM
TV cable ?
Post by shortbedCUSTOM »
ok, here is my dilema. I have a '70 model Ford short bed that when I bought, had a 4speed on the floor. since then, the tranny has been removed and replaced with a 5speed TREMEC. now the 5speed is out and an AOD in it's place. my question is this, do I need to use a TV cable and what is it's purpose? is there a bracket I need for this cable and where can I get one?
I'm also using a B&M floor shifter that I bought off a buddy. is there a bracket kit that I need to make this shifter work with my AOD? he was using it on a chevy 700R.
basketcase0302
re: TV cable ?
Post by basketcase0302 »
shortbedCUSTOM,
I can't help you with the TV cable thing but...
All B&M shifters used to come with a couple of different brackets, (one for th350, one for c-4, one for c-6, etc.).
I think their shifters are awesome, (I've got the "truck" one to go into my future bump build)!
Can you identify it from one of these:
http://www.bmracing.com/index.php?id=pr ... 2&subcat=1
If so, they do have a tech department that could get you the right mount.
Hope this helps,
craftsman
Post by craftsman »
Yes you have to use the tv cable, it controls shift points( pressure in the trans) you will burn it up without it. Here is an option to hook it up
http://www.jegs.com/webapp/wcs/stores/s ... 2_73708_-1
Here is how to adjust it.
http://www.becontrols.com/tech/tvlinkage.htm
FLATBEDFORD
Post by FLATBEDFORD »
I think you'd be better off going with satellite. You'll need a lot of cable, or you'll have to stay close to home. Actually, turn off the TV and watch where you're going.
What is a TV cable?
My Photo Gallery
DuckRyder
re: TV cable ?
Post by DuckRyder »
"Throttle Valve" cable.
Lokar makes what you need, you absolutely MUST hook it up, and you cannot use a stock one with a carb.
shortbedCUSTOM
Re: re: TV cable ?
basketcase0302 wrote:shortbedCUSTOM,
Hope this helps,
ok, thanks. I have the MegaShifter but I bought the shifter off a friend and he had it installed on a 700R (chevy) so he gave me is what I got.
those cables are expensive... they're more than what I paid for the tranny.
Leadfoot
re: TV cable ?
Post by Leadfoot »
Tv what?
but as for cable shifters make sure you carry a spare cable. nothing sucks more than when they snap and leave you screwed. :2cents:
WHAT ?
shortbedCUSTOM
re: TV cable ?
ok, I guess I should of mentioned that the tranny came out of an '89 Stang. it has the stock TV cable still attached. can I use that cable? if so, I'm assuming that ALL I need is the bracket to attach it to the Edelbrock carb I am using. can someone point me in the right direction for this bracket?
what I thought was going to be a one weekend swap has turned into a nightmare. :cry:
FLATBEDFORD
Re: re: TV cable ?
shortbedCUSTOM wrote: what I thought was going to be a one weekend swap has turned into a nightmare. :cry:
I think we've all had that happen. :D
My Photo Gallery
cathynkeith
Post by cathynkeith »
the 2200 missing from my check book says yes you do need a tv cable, man I could have got a tv in dallas for 50 bucks.........
http://s115.photobucket.com/albums/n292 ... type=local
Life is good...... when nothing is wrong that money can't fix.
1969 f100 flareside
1962 ECONOLINE TRUCK (done)
1975 Nova (almost done)
DuckRyder
Re: re: TV cable ?
Post by DuckRyder »
shortbedCUSTOM wrote:I'm assuming that ALL I need is the bracket to attach it to the Edelbrock carb I am using. can someone point me in the right direction for this bracket?
No one can point you to said bracket because one does not exist. The geometry is all wrong and any attempt to adapt the stock cable set up will likely result in the TV valve in the transmission being destroyed.
Lokar has what you need...
cathynkeith
these guys will know, they set up my holly and aod
http://www.transmissioncenter.net/aod.htm
1969 f100 flareside
DuckRyder
Post by DuckRyder »
cathynkeith wrote:these guys will know, they set up my holly and aod
Wherein they are selling
Wait for it...
LOKAR :D
That is a nice bracket, but the fine print on the photos say it requires the cable kit. It is quite a bit more elegant than the one Lokar provides with the cable.
