hello,
I wasn't to sure witch thread to post this on but anyway, I just wanted to know if they will bolt up together. Just some info would be nice, anything. thanks!
85-302 & 67-C6 trans
- basketcase0302
re: 85-302 & 67-C6 trans
worlds,
The C-6 transmission with the small block housing is hard to find. I've got one for a future project. Most of the C-6's were for the big block Ford engines, (351M/400M/460M/etc.). And I do know the 85' 302 would not have the 'hole" for the "Z" bar for a clutch as those years would use a "wet" clutch.
Here's the really good tutorial Keith has provided for us that tells a lot more:
http://www.fordification.com/autoID.htm
Basketcase
Basketcase
- craftsman
It will bolt up long as it is a small block bellhousing c6,240,300, 302, 351w, be sure to use a 50oz balance flexplate. The 302 changed from 28oz to 50oz in the early 80's. If you have a 67 c6 it's probalbly from an fe engine.
Ford use c6 trans behind the 302 starting in 78, maybe 77 but for not for sure on the year. Hope my
helps. ![Thumbs up :thup:](./images/smilies/icon_thumright.gif)
The small block pattern is not hard to find around here. BUT, if you are not planning on towing much or often I would recommend the c4 or c5.
I swapped from a c6 to a c4 once when I still had a small block in my 71 and was totally surprised by the extra amount of power I got just from the swap.
The C6 uses alot of power to operate.
clint
clint
71 F100 SportCustom
1986 Bronco 5.0 AOD
1986 Bronco 5.0 AOD
- ToughOldFord
AFAIK the '67 didn't use the C6, it used the FMX.
