tranny pan removal question
SteveC
Post by SteveC »
Ok this friday im planning on tackeling the replacement of my tranny gasket and filter.
My question is that since my pan sets sideways and part of the bolts are between the crossmember and the pan looks like it will be fun to get it...and suggestions on making this a easier job or is it gonna just be a grand old fun time the ones im talking about are above the crossmemeber and between the bellhousing and the pan its self thankyou
1967 f-100 4x4
1988 ford f150 xlt lariat
1961 VW Beetle (wifes car)
BobbyFord
Post by BobbyFord »
1/4 drive 1/2" flex socket works well in those tight spots. I suggest taking it down to the local do-it-yourself car wash and pressure washing the trans so that you can find the bolts and not get any unnecessary dirt anywhere in the trans...:)
SteveC
re: tranny pan removal question
Post by SteveC »
she is a little dirt under there... my valve covers are leaking and so is the back of the intake...gonna fix the valve covers this friday along with the tranny pan ...
i believe dad has a pressure washer at his house were my truck is right now
thanks though ill make sure to take my universals and other stuff with me
1967 f-100 4x4
brainfart3
Post by brainfart3 »
I removed the same pan a couple weeks ago.
the front pan bolts aren't too difficult - i used a short extension rather than a "wobble-joint".
after all the bolts were out the pan dropped down - was able to move the pan around under there (shifting from side to side and sliding up out of the way) but never did get it to come all the way out.
SteveC
Post by SteveC »
might be asking a stupid question but did you unhook the dip stick tube from the pan?? that is how i drained mine and after i did that the pan was fairly easy to get out of there...no factory plug though..
1967 f-100 4x4
brainfart3
yup - that's the easiest way to drain it.
right now i'm swapping teh Cruiseomatic for a 72 C6.
couldn't find anyone willing to rebuild the old COM
SteveC
Post by SteveC »
dependin how mechanicaly sound the tranny and engine is i may rebuild them my self
1967 f-100 4x4
