Can I take the 9" pumpkin out of my 81 and swap it right into my 68 9"?
The 81 has traclock and the 68 is an open rear. I want to roast both rear tires when I swap in the big block.
9" swap question
- iamthewreckingcrew
9" swap question
68 F-100 Short Box 2wd
302/c4/3.50
81 F-100 Long Box 2wd
460/c6/3.00
92 F-150 Lariat 4wd
302/auto couldn't go wrong for $500
302/c4/3.50
460/c6/3.00
92 F-150 Lariat 4wd
re: 9" swap question
Crap. And I suppose the axles in the 81 are too long too, huh?
302/c4/3.50
460/c6/3.00
92 F-150 Lariat 4wd
302/c4/3.50
460/c6/3.00
92 F-150 Lariat 4wd
- F100builder
If you have the $$$, you can do the swap and buy new axles with any spline and length you want. I've seen axles for a little as a couple hundred for the pair.
Patrick
![Image](http://i264.photobucket.com/albums/ii183/F100builder/1969%20F100/P3220011-1.jpg)
![Image](http://i264.photobucket.com/albums/ii183/F100builder/CAXW6TDZ-1.jpg)
![Image](http://i264.photobucket.com/albums/ii183/F100builder/Copyofscan0019-1.jpg)
![Image](http://i264.photobucket.com/albums/ii183/F100builder/Copyofscan-1.jpg)
