tranny help needed...pic request
Can someone post a picture of the tranny cross member for a C6 transmission...I am going to have to locate one, I think.
Thanks in advance!!
Thanks in advance!!
I think that I need the one that bolts to the rear of the transmission, but if you could get me a pic of both that would be great so I can determine what I have...Thanks!fordman wrote:i dont have a pic right now but i do have a crosmemeber if you want one. i can get a pic when i get it off the truck. do you want the front or back crossmember pic? the truck has both of them on it.
i put them in my truck for the ride home but my brake caliper stuck and was getting the rotor hot so i left the truck at dads . and got a ride home 30 miles. i will get pics as soon as i can it looks like i have to spend abouty 100.00 to replace the caliper and the rotor has been warped since i got the truck back in 2001
ok, thanks for the update...I will be looking forward for the picsfordman wrote:i put them in my truck for the ride home but my brake caliper stuck and was getting the rotor hot so i left the truck at dads . and got a ride home 30 miles. i will get pics as soon as i can it looks like i have to spend abouty 100.00 to replace the caliper and the rotor has been warped since i got the truck back in 2001
- iamthewreckingcrew
re: tranny help needed...pic request
Just for clarification, the rear one is the flatter one, right? It's the actual transmission crossmember. That other one is the front crossmember, correct?
68 F-100 Short Box 2wd
302/c4/3.50
81 F-100 Long Box 2wd
460/c6/3.00
92 F-150 Lariat 4wd
302/auto couldn't go wrong for $500
302/c4/3.50
460/c6/3.00
92 F-150 Lariat 4wd
- sideoilerfe
Re: re: tranny help needed...pic request
Correct!iamthewreckingcrew wrote:Just for clarification, the rear one is the flatter one, right? It's the actual transmission crossmember. That other one is the front crossmember, correct?
1970 F250 4x4 390/4spd
1968 F250 4X2 360/C6/No Rust!
Soooo, the tranny does not actually bolt to the cross member???
I think that I have that rear cross member, just a bit uncertain here![Confused :?](./images/smilies/icon_confused.gif)
