![Doh :doh:](./images/smilies/icon_doh.gif)
rear wheel leaking
rear wheel leaking
There is some type of oil leaking from my passenger rear wheel. It is almost like gear oil. Have not taken it apart yet but whatever it is it seems to be comeing from the hub and running down my tire on the inside and there are 2 big spots in my driveway. Any ideas what this could be? FInally got the tranny to stop leaking and now I have a new leak. ![Doh :doh:](./images/smilies/icon_doh.gif)
I love my old truck.
- iamthewreckingcrew
re: rear wheel leaking
Probably an axle seal. Possibly brake cylinder leaking.
68 F-100 Short Box 2wd
302/c4/3.50
81 F-100 Long Box 2wd
460/c6/3.00
92 F-150 Lariat 4wd
302/auto couldn't go wrong for $500
302/c4/3.50
460/c6/3.00
92 F-150 Lariat 4wd
- MadMaxetc
If it is brakes it will have very little odder.
If it is Axle fluid it will stink like all hell.
Dan
FORD Girl
Photobucket Pictures
FORD Girl
- ford4x4fun
I'm just picturing the neighbors walking by while he's out in the driveway with his nose to the ground.
![Loco :loco:](./images/smilies/icon_loco.gif)
Yeah, used gear oil smells terrible.
302/c4/3.50
460/c6/3.00
92 F-150 Lariat 4wd
302/c4/3.50
460/c6/3.00
92 F-150 Lariat 4wd
- MadMaxetc
fordman wrote:also check the axel breather for plugs. if its plugged it can force gear oil out of the axel seals.
Dan
FORD Girl
FORD Girl
- F100builder
A warped bearing? I haven't heard of that.
You'll need to press or have someone press the new bearing on and I'd grab a $5 seal and replace it too while you're at it. Does the axle look OK where the seal rides or is a groove present? If there is a groove, a new seal probably won't seal and you may need to get the axle built back up and then machined back down to spec. I've also seen rear end housings that are warped from people welding on them. It's nothing that you can really see with the naked eye but they go through seals in a hurry.
Patrick
![Image](http://i264.photobucket.com/albums/ii183/F100builder/1969%20F100/P3220011-1.jpg)
![Image](http://i264.photobucket.com/albums/ii183/F100builder/CAXW6TDZ-1.jpg)
![Image](http://i264.photobucket.com/albums/ii183/F100builder/Copyofscan0019-1.jpg)
![Image](http://i264.photobucket.com/albums/ii183/F100builder/Copyofscan-1.jpg)
Yeah the inside of the bearing was dry as a bone. The meatal piece that seperates each individual bearing was broken. I also grabbed a seal but I cant seem to get the old one out. Will work on it more this weekend. Had to heat up the other bearing and press it out. Gonna take the new one and have it pressed on.
