I think some of the smallblocks(newer maybe) didn't have the provisions to attach to the block. Seems like a lot of Mustang guys use a cable clutch instead.
68 F-100 Short Box 2wd
302/c4/3.50
81 F-100 Long Box 2wd
460/c6/3.00
92 F-150 Lariat 4wd
302/auto couldn't go wrong for $500
That is the spot that was / is on my 68 289/302 block in my mustang... I think it was the early blocks that didn't have it, like the early 289 and 260 pre 65 I think.
But that is the place on the block for it.
Shayne
All of the earlier small blocks I have worked on had the threaded bosses. 2 later 5.0 blocks had the boss for it but it wasn't drilled and tapped. 1 5.0 block didn't have the boss at all.
The 71 Mustang I had with a Cleveland used a bracket similar to that even though the Cleveland had a drilled and tapped boss.
Clint
Both styles actually place the z-bar very close, other than the "stud" style positions the bushing closer to the frame. It will save me from stretching my z-bar.
Anyone have a good description or even a part number for the "fuzzy" bushing that is on the bracket above???
