speedometer cable question
i am working on my 70 ranger, i did a front clip from a 89 crown vic. i also used the 302 and aod trans. my question is will i be able to hook up a cable from like a c6 trans or something. i have no cable now, and i have a guage cluster from a f600. i now most everything on the aod as far as bolts is metric but i don't know if there is a cable that would work with it and the old stock guages? does any one have any idea, or some place i can look? i hate to order cables that i can not use. thanks
- craftsman
re: speedometer cable question
this is a quote: Speedometer Gear
The speedometer driven gear assembly from the '71, including bolt and
retaining clip, slipped right into the AOD. I didn't get a chance to verify
the ratios, but the speedometer operated normally. There may be some
variation (seven and eight teeth gears?) with the AOD drive gear (the gear
inside the tailshaft housing), so you may have to change driven gears for
proper calibration
A c4 cable will work. And read this one
http://forums.corral.net/forums/showthr ... ?p=7617753
One more
http://www.allfordmustangs.com/forums/c ... ssion.html
proper calibration
One more
thank you craftsman, this is very helpfull.
