shifter cutout
- customcrewcab
shifter cutout
re: shifter cutout
thats sick looking! Did you make it yourself?
Tony
- kaptnkaos
re: shifter cutout
Nice clean install CCC, looks good...
- customcrewcab
Re: re: shifter cutout
yes and no. i designed it in autocad and sent it to the waterjet to be cut out. i still need to file the edges and give it that brushed look. 20 bucks to cut it and that was with materials. gave my buddy a few bucks to drill and tap it with a 5/16 and then he made an adapter for the ball because its 16mm. he's got the mill and lathe.Pipes71 wrote:thats sick looking! Did you make it yourself?
