1968 F250 91K miles, 2WD C-6...
I'm sure it's just strange because I don't know what's going on. Here's the story:
I had the C-6 rebuilt a few months ago. It leaks like this:
After driving it, no leaks the first day the truck sits all day. Second day the truck sits, no leaks. Third day the truck sits there are a few spots of tranny fluid. Sometime around the third to fourth day, the transmission dumps a whole lot of fluid onto the driveway.
I took it back to the shop and told them that it was leaking. They kept it overnight and returned it saying they hand adjusted bands and tightened something. Once I let the truck sit as described above, it did the same thing.
This took a while to discover, since I usually drive the truck everyday, or every other day. It seems that if I drive it, there are no leaks for a day or two. It only leaks when I let it rest for several days in a row.
I plan on taking it back to the shop. But before I do, I'd like to get some input to compare to what the shop is telling me.
There are only so many seals from which to leak, right? Is the pressure keeping a seal sealed, and when the pressure drops, then the seal doesn't, and the trannt starts to leak? Does that make sense? Is there a seal that behaves this way? I'd be happy to give it a go myself if there is a seal that I should redo.
C-6 Strange Leak
- J. W. Hall
C-6 Strange Leak
1968 F250 360 C6AT; aka "Otis"
re: C-6 Strange Leak
I have rebuilt a few C6 and C4 autos. Something in the build is wrong. Sounds like the shop needs to pull it and take a better look. You can't where the leaking is comming from? I might be able to give you an idea if you can give me a general idea of where the leak is.
My C6 does the same. I was told that the torque convertor is starting to drain back from sitting, and was told it was coming out of the gear selector seal. Mine isn't rebuilt though.
66 LWB, 1st car, still have
69 SWB, FOR SALE
03 Mustang Cobra, Zoom-zoom
69 SWB, FOR SALE
- Wes
Wes
67 F250 High boy
69 Bronco
If you can't see fit to stand behind Our Troops...Please stand in front of them
67 F250 High boy
69 Bronco
