speedo cable question
- SteveC
IM on break from work so ill keep this short.
I this after noon found out that my speedometer is WAY off from what i thought it was saying around 25-30 but i found out im going 38 since i got a nice lovely 219 dollar ticket for speeding.
The speedometer pointer bounces at low speeds and im guessing is in accurate at all times is there a way to make it more accuarte??
I dont have stock tires and dont know the size right off hand and can post them later.
Any help to get this sorta resolved so i dont have another ticket would be welcomed and apreciated.
Thanks again
Thanks again
1967 f-100 4x4
1988 ford f150 xlt lariat
1961 VW Beetle (wifes car)
1967 f-100 4x4
- Wes
when the speedo needle bounces, normally means the cable is dry and sticks for moment, then releases sticks again etc. Get some graphite from hardware or lock shop.
undo the cable housing from speedo end remove the cable wipe it down with clean rag, then squrit some graphite in housing. Start feeding the cable into housing applying graphite as you do. this should solve the bouncing, if not you prob need a new housing and cable.
The accuracy of your speedo may be the finial gear ratio to speedo gear miss match.
Hope this helps that a hell of fine in this economy.
Wes
67 F250 High boy
69 Bronco
If you can't see fit to stand behind Our Troops...Please stand in front of them
67 F250 High boy
69 Bronco
- SteveC
re: speedo cable question
thanks i figured that is what i needed to do. I know that the gears are all factory the only thing i changed was the tires which are taller. dad said that will throw off the speedometer.
I will graphite the cable and jsut try to remember that its off a bit. and if the cable is bad ill just wait to get a different one when i go to put the np435 on it.
Thanks for the help and ya that ticket is pretty high but im just gonna pay it and be over with it.
1967 f-100 4x4
1967 f-100 4x4
If you can prove your speedo is off and prove you fixed it, you could probably get out of the ticket. Either way good luck with the repairs
1970 F250 Camper Special
- SteveC
i thought about that but i just dont want to go through all of the court date stuff. Just live and learn.
Can i change gears in the transmission for the taller tires with the 4.10 ratio
1967 f-100 4x4
1967 f-100 4x4
- knightfire83
Re: re: speedo cable question
BiggDogg wrote:If you can prove your speedo is off and prove you fixed it, you could probably get out of the ticket. Either way good luck with the repairs
It would be worth it to try and get out of it. Your insurance premium will go up $$$ with that ticket for several years.
And yes, taller tires will make your speedo run slow. You can check by how much with this sites Java applet:
http://www.miata.net/garage/tirecalc.html
Good Luck
1974 Ford F-100 4x4- 360 / manual.
1970 Ford F250 4x4 ~ Sold.
- SteveC
well i pulled the cable out of the housing today it was pretty dry i sprayed it down with graphite lube and sprayed it into the housing as i fed it back in. took it for a spin and it only bounces a little at first till you get to 15mph and then it evens out. Even when it does bounce its not as bad as it was
1967 f-100 4x4
1967 f-100 4x4
- sideoilerfe
That shouldn't matter beings that the speedo cable connects to the transfer case and not the tranny.SteveC wrote:
1970 F250 4x4 390/4spd
1968 F250 4X2 360/C6/No Rust!
- SteveC
on a two wheel drive np435 it connects to a transfer case??
1967 f-100 4x4
1967 f-100 4x4
Should connect to the output shaft of the tranny.
Corbin
Corbin
Honestly, I really would rather push a Ford than drive a Chevy.
1969 F-100 4x4 Dana 44 w/ disk brakes and power steering conversion 390 c6 np205.
1970 F-250 97k original miles bone stock 390 np435 most original unmolested truck I have ever owned.
2001 F-250, Extra Cab, 4x4, 7.3 Direct Injected Turbo Diesel, Edge Programmer, Flowmaster 4" Turbo back Exhaust, 3" Leveling Kit with 33" Goodyear Wrangler DuraTracs, and has 250,000 miles and counting.
- SteveC
that is what i firgured the previous owner torched the cable off when he removed the tranny
1967 f-100 4x4
1967 f-100 4x4
- sideoilerfe
I'm sorry, I thought you had a 4x4.SteveC wrote:on a two wheel drive np435 it connects to a transfer case??
- SteveC
its ok thanks for the help thou... when i read that it was late and i was tired...but i started thinking i was crazy
1967 f-100 4x4
1967 f-100 4x4
