E4od help needed
- fourtss
E4od help needed
it's the 3 speed w/OD, it has the push button on the dash, when you put it in drive, the whole truck shimmy's goin down the road, come to a stop put the tranny shifter in low or second gear truck runs fine, shift into drive back to serious vibration, I put in a new torque converter no difference, anyone got any ideas?
tom
2003 ford escape
1997 dodge 1500 4wd 5speed, 1963 Cheby Corvair,
2003 ford escape
- ToughOldFord
re: E4od help needed
Oh man, the e40d, never again. I feel your pain.
- binder56jd
there is some trans additive made especially for that problem--it helped an aod i had in a van
Instant Shudder Fixx By Dr. Tranny (2 oz.)
and make sure all your linkages are fine tuned --those things are real tempermental
now serving #235
now serving #235
- binder56jd
now serving #235
now serving #235
Sounds like converter clutch shudder, I've had good luck with ATP brand synthetic additive. Try putting a bottle in it will usually stop right away if its going to work at all.
Good luck
Good luck
- fourtss
okay so I've try to contact the becontrol, no reply, use the stuff for the oil, no good, was wonderin, what a 4 speed tranny or maybe a five speed from same era would cost me, it has the 4.9 six (300) in it. Any ideas as to what a good used one would cost me? also, this truck is 4x4, will my transfer case mount on this tranny, or would I need a different one?
tom
2003 ford escape
2003 ford escape
