Well I could only get one side of the leaf spring to bolt up, the other end is of about 1", guessing that the spring needs compression to line up?
So should I half bolt the spring in place and then jack up the spring so it flexes enough that I can get the other bolt in, or bolt the spring to the axle and install it all at one time?
Im trying to do this the easiest way passable now that I have it all painted up and looking good.
