bellhousing/starter matchup question
blacktruck
Post by blacktruck »
Another questiom from the FNG.
The bellhousing that came with the truck(D7BP 7976 AA)doesn't quite fit a starter sold for your run of the mill 302.
Came with a "custom"horseshoe shaped plate that fits over the cutout mounting ears,makes putting the starter
in a real hassle.
157 teeth on the flexplate,C4 behind a 302,I've checked so the 77bronco starter is the same # as the one thats in there....
what do I need to get?
blacktruck
Re: bellhousing/starter matchup question
here I go again answering my own Qs
found this link on fordmuscle http://mmerlinn.com/catalog/miss_yoodil ... tm#default
tons of casting numbers in that site
discovered the bellhousing that I've got is designed for a 164 tooth flexplate :doh:
makes me wonder if they didn't build the whole truck at a pick and pull
FORDification
Site & Forum Admin
Site & Forum Admin
Post by FORDification »
Thanks for the link! Good info! :thup:
